Shift bushings., Any suggestions |
PeeGreen 914 |
Feb 4 2008, 11:50 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I am going to replace the bushings at the firewall and on the transmission. Anyone know the best place to get them and is there a better type than the stock? My car is primarily an AX car.
Thanks |
TROJANMAN |
Feb 5 2008, 12:27 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
all of the usual suspects carry the shift bushing kits.
PeeGreen 914 |
Feb 5 2008, 12:31 AM
Figured as much, but was just checking to see if one of our members had a line on some or if there were any that were better than others.
Tom |
Feb 5 2008, 12:39 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Jon,
I got mine from Pelican a couple of years ago. That firewall one was a real pain to get in. Finally had to cut a slice in the front part to allow it to compress enough to go thru the firewall. The others did not fit well due to wear of the shift rod and trans console, so I made some from delrin. They are working fine, but the jury is out on how long they will last. Tom |
PeeGreen 914 |
Feb 5 2008, 01:06 AM
Cool. I don't really think it will be to tough to get them in. I have done them a few times, but the people always supplies the parts (IMG:style_emoticons/default/wink.gif) We have some handy dandy tools that help in this. So how did you make yours?
chris914 |
Feb 5 2008, 02:00 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
The hard plastic one in the fire wall was real hard for me. Here is a link on how I did it.
Scroll down to "I converted my tail shifter to a side shifter. The shifter rod bushing that goes into the firewall was a bear to get in. So I made a tool to press it into place." http://www.cassidy-online.com/porsche914/ |
PeeGreen 914 |
Feb 5 2008, 02:04 AM
That looks rather clever. Like I said, we have some handy little tools that make that job easyish.
rhodyguy |
Feb 5 2008, 07:40 AM
when morgan stein's car was at dave ellisons i slipped the new one on the front rod while the old fw bushing was still in the car. the old bushing had a tighter tolerance than the brand new one. i told him why bother with it.
k |
whitey |
Feb 6 2008, 01:33 AM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I heated my bushing at the firewall in boiling water to make it softer...seemed to work much better for the install.
Joe Ricard |
Feb 6 2008, 06:31 AM
If you want to get really stupid you can get a spherical bearing with a nylon bearing surface.
I used steel it is very tight. Nearly no detectable jiggle. You got to weld in the race and you got to turn down the shift rod to match fit. Bronze bushing at the shift console. Next is to put a U-joint in place of that stupid coupler. |
CMONNETT |
Feb 6 2008, 08:12 AM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
The firewall bushing is easy to put in. All you have to do is take the 3 bolts out of the front shifter assembly and slide it forward till the rod is out of the engine bay. Then the bushing just pops in place. Put the shift rod back through the bushing and bolt the assembly down and your done.
Chris |
Cap'n Krusty |
Feb 6 2008, 09:51 AM
The firewall bushing is easy to put in. All you have to do is take the 3 bolts out of the front shifter assembly and slide it forward till the rod is out of the engine bay. Then the bushing just pops in place. Put the shift rod back through the bushing and bolt the assembly down and your done. Chris "Easy"? "Just pops into place"? You must have the wrong bushing. I believe others who've done this job will agree. The Cap'n |
CMONNETT |
Feb 6 2008, 10:27 AM
When you're not trying to slide it over the rod to put it in place it does go in easy. If the rod isn't in the hole, then you have the room for the bushing to give. This way you're not trying to compress it between the shift rod and the firewall. I've done this on many 914's, and yes I was using the right bushing. Think about it, if the shift rod is taken out of the picture, the bushing will pop intp place with a light tap from a deadblow hammer.
Chris |
jasons |
Feb 6 2008, 10:43 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
One improved bushing I used was the Patrick Motorsports Bronze trans console bushing. It seems to be a little smaller on the ID hole. And the overall OD is bigger to accommodate the often wallowed out hole in your suspension console. From my experience when I installed my Rennshift, this was the biggest culprit for lash in the linkage. A little bit of slop here propagates to a lot at your hand.
http://www.patrickmotorsports.com/part/592/ |
Cap'n Krusty |
Feb 6 2008, 10:50 AM
When you're not trying to slide it over the rod to put it in place it does go in easy. If the rod isn't in the hole, then you have the room for the bushing to give. This way you're not trying to compress it between the shift rod and the firewall. I've done this on many 914's, and yes I was using the right bushing. Think about it, if the shift rod is taken out of the picture, the bushing will pop intp place with a light tap from a deadblow hammer. Chris I've never even thought of doint it with the rod in p[lace, and in the 35 years I've been installing them (without that cool tool shown earlier, I've never found it "easy". I most often do them with the engine out, and have found it a bear to get in right. I use 2 BFHs and generally am able to get it in one powerful whack, but it's not "easy"........ The Cap'n |
Jeffs9146 |
Feb 6 2008, 04:28 PM
PeeGreen 914 |
Feb 6 2008, 04:32 PM
Thanks guys. I ended up just calling Jim and having him send me his monoball bushing and the bronze bushing. I really like the Jwest system, but he is sold out at the moment. I may have to do that at a later date.
Feb 6 2008, 05:09 PM
When you're not trying to slide it over the rod to put it in place it does go in easy. If the rod isn't in the hole, then you have the room for the bushing to give. This way you're not trying to compress it between the shift rod and the firewall. I've done this on many 914's, and yes I was using the right bushing. Think about it, if the shift rod is taken out of the picture, the bushing will pop intp place with a light tap from a deadblow hammer. Chris I've never even thought of doint it with the rod in p[lace, and in the 35 years I've been installing them (without that cool tool shown earlier, I've never found it "easy". I most often do them with the engine out, and have found it a bear to get in right. I use 2 BFHs and generally am able to get it in one powerful whack, but it's not "easy"........ The Cap'n Wow, I totally agree with the Cap'n This bushing sucks. Rich |
Trevorg7 |
Feb 7 2008, 09:34 AM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
Jon, That firewall one was a real pain to get in. Finally had to cut a slice in the front part to allow it to compress enough to go thru the firewall. Not sure you have to cut one to fit but as many have said they are a pain in the butt. I boiled mine and kept it really really hot, therefore soft, and I got it in. Good luck. T |
PeeGreen 914 |
Feb 7 2008, 11:58 AM
Not going to have that problem anymore as I am going with something much different. It will be very tight (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 08:40 AM |
