OT: charging deep cycle battery, is this normal? |
gopack |
Feb 5 2008, 09:27 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
I purchased a battery backed up sump pump last summer after we had (while out of town for the weekend) 8 inches of rain in 8 hours AND a power outage. we came home to a very wet basement. now as spring approches (we hope) i checked the battery and found it discharged. the control unit should keep the charge up, but I need to figure out what is up there. my question is this. after having the battery (deep cycle 12 volt) on the charger for 14 hours, there was leakage of the electrolyte out of the vent caps. is this normal? or did i fuch something up?
TIA for the help |
messix |
Feb 5 2008, 09:31 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what amp setting did you charge it at?
gopack |
Feb 5 2008, 10:28 PM
it had a 2 or 6 amp setting so i used 6
messix |
Feb 5 2008, 10:33 PM
it should be fine.
you should check it with a load tester and a voltmeter to make sure it still has a healthy capacity |
Lo-Fi Version | Time is now: 16th May 2024 - 04:09 PM |
