HOW TO: Convert to real 5-lug in the rear using 944 CVs |
SirAndy |
Feb 6 2008, 01:38 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Convert to real 5-lug using 944 CVsThis Article describes how to convert the rear axles on your 914 to give you real 5-lug hubs using a mix of 914, 944 and 911 components. Tools and Supplies:
Step 1: Preparing the axle shafts Remove the CV joints from your old axles and machine both ends of your axle shafts to allow the wider 944 CVs to slide on. You'll have to remove 4mm of material to make up for the wider 944 CVs. 4mm of material removed: Stock 914 CV on the left and a 944 CV on the right Step 2: Putting it all together Grease up your new 944 CVs and slide them on the machined axle shaft *without* using the stock spring washer behind the CV! Make sure the CV slides all the way on and don't forget to put the circlip back onto the shaft to prevent the CV from sliding off. Note: Make sure the "groove" on the outside of the new CVs always points away from the axle (see picture with the complete axle). Remove the old stub axles and hub. Remove the old wheel bearings. Install the new wheel bearing in your trailing arms. Make sure the bearing surface on your new hubs is clean and press in the new hubs. Install the new stub axles and tighten the axle nut. Remove the old output flanges from your transmission, replace the seals and slide in the new 911 flanges. Grease up both, the output flange cup and the stub axle cup and install your new axles. Don't forget the CV seals! Tighten everything to spec and enjoy! 911 coarse spline output shaft and 911 stub axle: 944 CV on 914 axle shaft: Test fitting the output shaft on the 944 CV: And at last, the completed axle. The top shows the original 914/4 axle, the bottom shows the new axle: Mounted on the car: |
-JR- |
Jun 21 2010, 05:09 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
Based on Andy's notes I've assembled these details on part numbers...
Rear hub 1969 --> 1973 "901 331 065 09" 911 T/E/S *Not Carrera" Rear Axel 1970 --> 1983 "901 332 232 00" 911 SC/SPM *Not Turbo* 944 CVs Any year, non-turbo "944 331 901 00" I haven't researched transmission flanges. They will depend on your transmission selection. |
jimkelly |
Jul 5 2017, 06:34 AM
so, are these parts still readily available these days and what price should one expect to pay a pair of the hubs and for a pair of the stub axles?
thanks jim Based on Andy's notes I've assembled these details on part numbers... Rear hub 1969 --> 1973 "901 331 065 09" 911 T/E/S *Not Carrera" Rear Axel 1970 --> 1983 "901 332 232 00" 911 SC/SPM *Not Turbo* 944 CVs Any year, non-turbo "944 331 901 00" I haven't researched transmission flanges. They will depend on your transmission selection. |
Lo-Fi Version | Time is now: 28th April 2024 - 09:19 AM |
