HOW TO: Convert to real 5-lug in the rear using 944 CVs |
SirAndy |
Feb 6 2008, 01:38 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Convert to real 5-lug using 944 CVsThis Article describes how to convert the rear axles on your 914 to give you real 5-lug hubs using a mix of 914, 944 and 911 components. Tools and Supplies:
Step 1: Preparing the axle shafts Remove the CV joints from your old axles and machine both ends of your axle shafts to allow the wider 944 CVs to slide on. You'll have to remove 4mm of material to make up for the wider 944 CVs. 4mm of material removed: Stock 914 CV on the left and a 944 CV on the right Step 2: Putting it all together Grease up your new 944 CVs and slide them on the machined axle shaft *without* using the stock spring washer behind the CV! Make sure the CV slides all the way on and don't forget to put the circlip back onto the shaft to prevent the CV from sliding off. Note: Make sure the "groove" on the outside of the new CVs always points away from the axle (see picture with the complete axle). Remove the old stub axles and hub. Remove the old wheel bearings. Install the new wheel bearing in your trailing arms. Make sure the bearing surface on your new hubs is clean and press in the new hubs. Install the new stub axles and tighten the axle nut. Remove the old output flanges from your transmission, replace the seals and slide in the new 911 flanges. Grease up both, the output flange cup and the stub axle cup and install your new axles. Don't forget the CV seals! Tighten everything to spec and enjoy! 911 coarse spline output shaft and 911 stub axle: 944 CV on 914 axle shaft: Test fitting the output shaft on the 944 CV: And at last, the completed axle. The top shows the original 914/4 axle, the bottom shows the new axle: Mounted on the car: |
stephenaki |
Feb 6 2008, 09:00 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
How does this affect the issue with the parking/emergency brake? I understand that the 911 conversion negates the use of the parking brake; does this have the same problem or is it a non issue based on the fact that your not changing out the entire suspension.
Uneducated minds would like to know. |
Richard Casto |
Feb 6 2008, 09:40 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
How does this affect the issue with the parking/emergency brake? I understand that the 911 conversion negates the use of the parking brake; does this have the same problem or is it a non issue based on the fact that your not changing out the entire suspension. Uneducated minds would like to know. I believe that e-brake issues are more of a function of moving away from the stock 914 rear caliper than a five lug conversion issue. For example you can do a five lug conversion and use a 914/6 rear caliper ($$$$) as the e-brake solution is the same for all 914 (4 or 6) calipers. But it is common to do a five lug conversion and at the same time move to a 911 (or other) rear caliper that uses a different e-brake solution than the 914 rear caliper does. |
stephenaki |
Feb 6 2008, 10:02 AM
I believe that e-brake issues are more of a function of moving away from the stock 914 rear caliper than a five lug conversion issue. For example you can do a five lug conversion and use a 914/6 rear caliper ($$$$) as the e-brake solution is the same for all 914 (4 or 6) calipers. But it is common to do a five lug conversion and at the same time move to a 911 (or other) rear caliper that uses a different e-brake solution than the 914 rear caliper does. OK, got it. My assumption is, correct me if it is wrong, that if I were to do Andy's conversion I would have to re-do the rear brakes or would the stock 914/4 system work with this conversion? Understand the stopping power is reduced with bigger wheels but if your not racing the car or increasing the power is it required to convert the brakes? I am still a novice at this so am trying to learn as I go along. |
Lo-Fi Version | Time is now: 27th April 2024 - 02:29 PM |
