Checking Transmission Oil |
ne14914 |
Mar 19 2003, 10:40 PM
Me N My914 Group: Members Posts: 94 Joined: 4-March 03 From: Los Angeles, Cali (Inland Empire) Member No.: 388 |
Ok guys - Anuder Dupid Kwestyawn (IMG:style_emoticons/default/confused24.gif)
How do you check the transmission oil? I cant seem to find a dip stick ~ |
Brad Roberts |
Mar 19 2003, 10:43 PM
No dumb questions... Feel free to ask anything you like.
Pull the fill plug on the side of the tranny and stick your finger in it. The fluid should just be at the bottom of the fill plug hole. Note that the tranny has 2 plugs. One is higher than the other (fill plug) and the other is the drain plug. B |
ne14914 |
Mar 19 2003, 10:48 PM
Thanks Brad
This is my first 914 and Im trying to learn as much as I can. |
Brad Roberts |
Mar 19 2003, 10:55 PM
You came to the right place. Lots and lots of very knowledgeable people on this BBS.
Dont sit back and watch the board. Always ask your questions. I can almost promise a response 24/7 within 30 minutes of your post. B |
Mar 19 2003, 11:01 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Sears or your local VW Bug shop should have the 17mm Allen socket you use to remove the fill plug.
Some have used a combination of nuts and bolts as a socket, but several people have messed up their drain or fill plugs using those. The real thing is pretty cheap... --DD |
airsix |
Mar 19 2003, 11:22 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(Dave_Darling @ Mar 19 2003, 09:01 PM) Sears or your local VW Bug shop should have the 17mm Allen socket you use to remove the fill plug. Some have used a combination of nuts and bolts as a socket, but several people have messed up their drain or fill plugs using those. The real thing is pretty cheap... --DD I walked into a FLAPS and said to the clerk "I need a 17mm allen wrench." He replied "We don't have any that big." So I said "Do you have a VW drain plug tool?" and he said "Sure, they're right here." And he handed me a 17mm allen wrench. -Ben M. |
Brad Roberts |
Mar 19 2003, 11:33 PM
Normally its a cheap "chrome vanadium" 3/8 drive 17mm socket. I buy two at a time.
B |
ChrisReale |
Mar 19 2003, 11:43 PM
and if you decide to drain the fluid, remove the filler plug before you remove the drain plug. Learned that a few days ago.
Brad Roberts |
Mar 19 2003, 11:50 PM
And... why do you remove the fill plug ??
B |
ChrisReale |
Mar 19 2003, 11:53 PM
so it acts like the carb on a bong! Try pouring a jug of water out into the sink. Observe the results. Then do the same, but cut a hole in the top. Much smooooother.
Mar 19 2003, 11:55 PM
Resident German Group: Admin Posts: 41,602 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Brad Roberts @ Mar 19 2003, 09:50 PM) And... why do you remove the fill plug ?? so it rinses out easier. ever made a hole in a beer can at the bottom and then opened the top? (IMG:style_emoticons/default/rolleyes.gif) Andy |
ChrisReale |
Mar 19 2003, 11:57 PM
Never tried it, but Ive seen it done numerous times. Maybe Ill give it a try.... (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/driving.gif)
Brad Roberts |
Mar 19 2003, 11:59 PM
Yes and yes...
newsflash... There is a BIG breather hole at the top of the tranny. If it is plugged.... your tranny will ooze fluid anywhere it can. I knew why you pulled it.... smart asses... (IMG:style_emoticons/default/finger.gif) B |
Dave Cawdrey |
Mar 20 2003, 12:14 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
QUOTE(ChrisReale @ Mar 19 2003, 09:57 PM) Never tried it, but Ive seen it done numerous times. Maybe Ill give it a try.... (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/driving.gif) You never shot-gunned a beer? Man, do I feel old. Atleast you recognize old school hip hop. Makes me feel young again (IMG:style_emoticons/default/cool_shades.gif) |
Mar 20 2003, 12:17 AM
QUOTE(Brad Roberts @ Mar 19 2003, 09:59 PM) I knew why you pulled it.... smart asses... (IMG:style_emoticons/default/finger.gif) hehe, works every time (IMG:style_emoticons/default/finger.gif) |
Curvie Roadlover |
Mar 20 2003, 06:21 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
The topic of why you open the fill plug came up about a week ago. I thought it was here, but maybe it was on the PP BBS. If you open the drain plug and fluid starts pouring out, then are unable to get the fill plug out, you will have a bitch of a time refilling and the car might be out of commission in the meantime. If you realize that the fill plug is stuck first, you can still drive the car (since you haven't lost your tranny fluid) until you resolve the stuck plug. I remember some people posted what a pain in the ass it was to try to fill the tranny from the breather hole. Just something to think about. (IMG:style_emoticons/default/driving.gif)
tahoward |
Mar 20 2003, 07:14 AM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
So glad to hear that happened to someone besides me...maybe I'm not cursed!! (IMG:style_emoticons/default/confused24.gif)
JWest |
Mar 20 2003, 08:46 AM
Here's the other discussion...
http://forums.pelicanparts.com/showthread....20&pagenumber=1 |
Lo-Fi Version | Time is now: 19th April 2024 - 03:52 AM |
