Front suspenion A-arm refurm, Step-by-step |
racunniff |
Feb 9 2008, 09:55 PM
volt914 Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains |
My car had the most annoying popping / grinding sound coming from the passenger's side front A-arm. It got to the point that I almost did not want to drive the car any more. So, I decided to do something about it. Once I had diagnosed that it was the A-arm bearings causing the sound, I went to the Pelican and ordered this part (part number 99-3014-340-M230):
You'll need the following tools:
I jacked the car up, and removed the wheel, so I could access the suspension: Here is what the A-arm looked like at the begnining of this whole process: First step in removing the A-arm is to remove the torsion bar adjusting screw (using an 11mm socket) and then pry the adjusting arm off the torsion bar (I used an Allen wrench as a lever to push it from behind): Next is to remove the tapered pin from the ball joint. You back the nut off so it's clear of the threads (using a 13mm socket) and then you *carefully* strike it with a hammer - here is my BFH about to strike the nut (which has been soaking for a bit in penetrating oil). You have to hit it pretty hard to loosen it, but eventually, it will pop forward: Once you get the initial "pop" you'll need to remove the nut and then use another bolt or something as a drift to push the pin far enough out so you can get at it with vice grips or something. Coming soon, Part II |
racunniff |
Feb 9 2008, 10:03 PM
Part II
Next, you need to pop the ball joint out of the strut. This is pretty tricky. I ended up using a long lever to push it down (not shown: I also put a jack under the brake rotor "hat top" to keep the strut from lowering as I pried): Next, you remove the rear bolt that attaches the A-arm to the aux front support (using a 19mm socket): Remove the front guard clip (using an 8mm Allen wrench - I had to actually use the key style, since my 8mm hex socket would not fit all the way in to the bolt (IMG:style_emoticons/default/mad.gif)): And then remove the two bolts holding the front of the A-arm on (using a 17mm socket): Coming soon, Part III |
Lo-Fi Version | Time is now: 6th May 2024 - 12:10 PM |
