Case Polishing, a labor of love |
McMark |
Jan 10 2004, 12:09 AM
Here's some pictures of the progress I made tonight. Very labor intensive but hopefully it'll look nice when it's done.
(IMG:http://homepage.mac.com/markd/Misc/polish/DSCN2278.jpg) (IMG:http://homepage.mac.com/markd/Misc/polish/DSCN2279.jpg) (IMG:http://homepage.mac.com/markd/Misc/polish/DSCN2283.jpg) |
Aaron Cox |
Jan 10 2004, 12:10 AM
mothers?
McMark |
Jan 10 2004, 12:18 AM
The case was bead blasted which left a rough surface. What I have to do is sand with 400 grit sandpaper, then polish with a rubbing compound and then a polishing compound. I am using a die grinder with felt cones for the rubbing and polishing compounds, but the sandpaper is all manual. I'm not that happy with the bead blasting of the case, but it's the only way to get rid of the oil stains.
Aaron Cox |
Jan 10 2004, 12:19 AM
kind of anal dont you think? (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/laugh.gif)
redshift |
Jan 10 2004, 12:21 AM
I got lazy doing that to my wheels, so I just etched them again.. (IMG:style_emoticons/default/smile.gif)
Just giving you a way out.. M |
914ghost |
Jan 10 2004, 12:27 AM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
I've used a drill w/ a couple different wire brushes before, you can get a little shine that way, and it actually leaves decent base for poishing-eliminates the raw fingers. Try using ...Eagle1 (I think) Mag wheel stripper stuff too instead of sandblasting, it etches the top layer of metal, removes whatever stains and coatings are on it. Just dont spray it on your wheels thinking it will 'clean' them- because it WILL- in a big way.
Luckily on a 914 you only have to polish the top of the case there. R O |
hargray2 |
Jan 10 2004, 12:32 AM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
Post pics of the end result when you're done say, mid August maybe? (IMG:style_emoticons/default/lol2.gif)
No seriously, that's gonna look great. You're surely not as lazy as I. |
McMark |
ghost, I'll check out the Mag Wheel Stripper. Sounds like good stuff. I'm not sure how far I'm going to go. I have a month or two before the internals come back from Jake, so I've got lots of time to kill. (IMG:style_emoticons/default/smile.gif)
skline |
Jan 10 2004, 12:34 AM
QUOTE(acox914 @ Jan 9 2004, 10:19 PM) kind of anal dont you think? (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/laugh.gif) Hey, I polished the top of my case when I had it apart, I just wanted to clean it up a little. The end result is not quite what I expected and it was a lot of work, but it looks better than it did. |
skline |
Jan 10 2004, 12:40 AM
Pictures?
Gint |
Jan 10 2004, 12:53 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Mark, you're going to at that job for a long time.
Tip for ya. After bead blasting, it's easier to start with a rougher grade paper. I used 80, then 200, then 400. And for wheels I went on to 1000. IIWY, I would start your sanding with 80 or 120. It will make the job a little easier. |
jonwatts |
Jan 10 2004, 12:59 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
I fear this. My subie engine has some crust on it (from the boat crossing I assume) and I fear trying to clean it up any will result in months of polishing like McMark is doing.
What's the best way to remove casting marks from aluminum? Dremel? |
Rich Bontempi |
Jan 10 2004, 03:30 AM
914 Road Racer Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California |
You could polish the case inside, it actually will be good for oil flow or quicker oil return to the bottom of the case depending on where you polish!!
redshift |
Jan 10 2004, 03:58 AM
QUOTE(jonwatts @ Jan 10 2004, 02:59 AM) What's the best way to remove casting marks from aluminum? Dremel? On outside curves, a nice hard-cut mill file. You have to get a rat tail for the inside curves, and you get real pissed off about 10 hours into it. M |
URY914 |
Jan 10 2004, 04:52 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,782 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Mark Henry |
Jan 10 2004, 07:48 AM
If you have bead blasted that case you better pull (and tap) your oil galley plugs.
I absolutely guaranty that you still have glass beads in your oil galleys, no matter how well you have cleaned the case. |
seanery |
Jan 10 2004, 07:56 AM
what are you gonna do to the case to keep it shiny after it's done?
mikester |
Jan 10 2004, 08:19 AM
Member Group: Members Posts: 326 Joined: 18-June 03 From: CA Member No.: 837 |
I wonder how it will affect cooling.
McMark |
Jan 10 2004, 09:31 AM
Mark H. - They're already out. (IMG:style_emoticons/default/biggrin.gif)
Sean - I was thinking about anodizing. |
mskala |
Jan 10 2004, 03:44 PM
You guys belong on a 911 list (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 24th May 2024 - 06:27 AM |
