engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Jan 10 2004, 06:38 PM
I must be fairly far off course by now.
(The battery is disconnected) The sticking point is the cabling that goes through the shroud. There is a baffle system immediately behind the fan (the alternator is in the center of the fan) and the cable goes through the back of the baffle and (from touch) splits into two). But how to get the cabling disconnected? The baffling system is held on by a myriad of bolts around its edge. It's conceivable that I could get to each bolt and remove it -- but reassembly would be a nightmare. I must be missing something. kim. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:51 AM |
