engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
bwilless |
Jan 10 2004, 09:16 PM
Member Group: Members Posts: 156 Joined: 24-January 03 From: Tempe, AZ Member No.: 192 |
I just did this on my 3.0, on an engine stand. There are ~8 bolts holding the baffle thing on. You have to remove these bolts, to slide the baffle back, to disconnect the wires. Mine had nuts on the wiring connections. It was not easy on the stand, I imagine in the car it will be difficult.
Have fun (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:56 AM |
