engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
meursault |
Jan 11 2004, 12:28 AM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
Or you could just take off the fan belt, remove the bolt(s) from the wide steel strap that holds the fan housing on, and remove the nut from the ground strap where it attaches to the case half. Then, assuming all other electrical connections on the engine wiring harness are disconnected, you can carefully lift out the shroud and fan/alternator as an entire unit. Fun, eh, removing all that stuff just to get to the alternator?
On my original six, it looked like some yokel cut the fiberglass shroud to get to the alternator, then reglassed it back together when he'd finished the work. (IMG:style_emoticons/default/icon8.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:21 AM |
