engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Jan 11 2004, 02:33 PM
Now we unbolt all shroud bolts. Most are visible. There are a coupel that are not. Front edge of the shroud has bolts (most interesting one is behind the dizzy) and there are two that are accessed from under the car on the drivers side, just up from the rear wheel.
Once those are off (and various wires are unhooked) the shroud will lift and can be weasled to the back of the engine. A camera can be shoved under the shroud and a couple of pics will show the diverter and the wires/etc. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:35 AM |
