engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
Gint |
Jan 11 2004, 02:42 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE (mike I've other pics from other angles -- these show most thing tho -- if you want more, let me know) (IMG:style_emoticons/default/wub.gif) That will do nicely KiM, thanks. now that you've showed me yours, I'll show you mine when I tear it apart to seal the motor after the car goes to the shop. (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 03:18 PM |
