engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Jan 12 2004, 11:19 AM
QUOTE(boxstr @ Jan 12 2004, 08:24 AM) Just got to this thread. Curious, why did you not remove the engine lid cover? CCLINBTDT Should have! (did not occur to me until someone else mentioned it -- and I was mostly done) I may yet pop it off for the reassembly steps -- it's funny, the entire procedure was not that bad once you knew what to do. I'm sure next time it would go much more quickly. We'll see how putting it all back together goes (IMG:style_emoticons/default/laugh.gif). kim. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:05 AM |
