engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Jan 24 2004, 08:50 PM
JP:
great point on the shopvac/fume issue. I'll be mindful. On your other point (am I the first? doubtful....), I'll have to dig out the docs from the purchase -- we're in a house reno situation and not all paper can be easily found. You ask "my point?" -- you've supplied it. I wouldn't have spotted what you easily did! (i.e. aluminum cylinders) Gint: If I fire brake cleaner down the cooler, will it land in a reasonably predictable area under the car? (i.e. we're in my car port -- I'm trying not to hose up the surface under it. It's already marked the tranny area as it's own .... but that's the next project. (IMG:style_emoticons/default/headbang.gif) ) kim. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:50 AM |
