engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Feb 10 2004, 09:45 AM
I noticed you had a carbon fiber one on one of the cars -- meant to ask you about that. Mind you, I was a lot more enthusiastic about the idea before I started this bit of silliness -- I'll be reluctant to remove it anytime soon (and certainly not for one with that much work to fit)!
It's getting light outside -- can I start again now? (IMG:style_emoticons/default/laugh.gif) (actually not -- it got below 40F here last night so "it's cold out there campers!") kim. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:17 AM |
