engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Feb 10 2004, 09:20 PM
So at the end of a long day, there's good news and bad.
The good news. Got everything reassembled, and with a fully charged battery, the machine came back to life. (to me this was a minor miracle -- I haven't done this much reassembly in some time...) The wiring seems correct. And it runs. (Gint, brake cleaner on exhaust stinks -- but it did work really well -- I'll post pics later) And it now has an exhaust leak it's never had before. (how can a sitting car on its sorry butt acquire an exhaust leak? too much effort to smile in the morning as I rust? must be spite) One of the carbs leaks at the accelerator pump. I guessedI would have to revisit the miserable suckers, so that wasn't that much of a surprise. I have complete carb kits, but I wanted to find out if the charging problem was solved, and I wanted to see how the jetting worked before ripping them to bits. Most of this was trial anyway -- tho I really don't wanna take that frik'n schroud off again. But here's the real ugly part -- the original problem continues to exist. The alternator light does not come off at any rpm. I suppose I could have something wrong that blew up a perfectly good alternator -- clues welcomed! -- but other than that, it seems the problem may be elsewhere. I'll look at it again in the morning. But thanks (IMG:style_emoticons/default/smilie_pokal.gif) for all your help! There's no way I'd have got this far flying solo. kim. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:16 AM |
