engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Mar 17 2004, 12:12 AM
I have one last pic. There are old webers and new webers. The carb on the left is an old one, and the newer on is on the right. The tell-tale is the quality of surfacing that is done on the outside casting. Inside these carbs look pretty much the same. They got chinzy over time and the outer casting was left rougher.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:40 AM |
