> Horn issues.
914Dan
post Feb 25 2008, 05:54 AM
The horn on my 914 came on and won't go off. I yanked the fuse so as not to annoy the neighbors, but it's stuck. I pulled the ring off and the rubber donut underneath is dry and all squished up. There is a wire coming up the column and grounded to a tab, that tab is broken off.
Does anyone sell a horn rebuild kit? I looked the the FAQ section but didn't see anything.
Thanx, Dan
pin31
post Feb 25 2008, 09:38 AM
Check AutoAtlanta...pdf catalog in "members stuff for sale" section.
ericread
post Feb 25 2008, 11:41 AM
The Viper Blue 914
If you have the new AutoAtlanta catalog, check page 57. I recently rebuild my steering wheel and included the following parts for the horn:
Horn Boot: G901 347 823 01 $12.71
Horn Contact Plate: G914 347 099 00 $39.54 ($15.00 Used)
Horn Base Plate: B914 613 805 A $29.50
Good luck!
AZ914
post Feb 25 2008, 12:06 PM
914 Dumbass
For competition sake.. I believe Pelicanparts sells them too
914Dan
post Feb 25 2008, 02:29 PM
Thanks guys. If I remember correctly, when I wiggled the wire without touching anything with the exposed wire, the horn went on. This tells me there's some bad Juju down inside the column.
I'll order the catalogs.
Thanx, Dan
- Lo-Fi Version Time is now: 16th April 2026 - 04:50 PM
