4 speed tranny stuff for the V8 and high HP /6 crowd, Pictures |
Dr Evil |
Feb 25 2008, 05:53 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Here is the latest gearbox I am building for someone. It is an F-N-X-HBf box and I wanted to show how easy it is to lock out 1st in a 4 speed box. I have heard that there are people that charge a chunk of change to do the same thing....I think that is wrong as it is way easy. All you need is a rear gasket, tubing cutter and a section of 3/8" copper tubing (1/2" shown as I bought the wrong size).
Here is the FNXHBf stack (Ooo, purdy). Here is the shift rod end for 1st that needs the sleeve to lock it out. I removed 1st gear completely other than the gear on the input shaft as you need it for reverse. And here is the section of ~2" copper tubing. You need to keep the slider for revers. It looks like the sleeve will hit the slider, but it is just the angle of the pic. |
Dr Evil |
Feb 25 2008, 08:09 PM
That seems like a tight grouping in the upper gears. Quite a bit of distance between 1 and 2 as well according to my chart.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 06:04 AM |
