Wire from alt, relocating battery |
spunone |
Mar 10 2008, 07:05 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Ok last Question for the day. Can I run the lrg Red wire from the alt direct to the Battery or do I need to go to the starter?Reason being moved battery to the trunck and used a thru body terminal connector on the drivers side with wire running to it Thanks Again
ejm |
Mar 10 2008, 07:10 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Direct to the battery is good, no need to stop by the starter.
spunone |
Mar 10 2008, 07:11 PM
Great thats what I was thinkin Thanks
Lo-Fi Version | Time is now: 17th May 2024 - 03:53 PM |
