> New suspension for Papa Smurf, ..or...how to spend a lot of $$ and get lots of benefit
naro914
post Mar 12 2008, 04:23 PM
Post #21
Losing my mind...
I thought I would share the latest upgrade we've done to Papa Smurf.
Over the years, the Carrera suspension on our 914 has been getting a bit "soft". the springs were shot - one was up higher on the perch in the back than the other, and all 4 shocks were leaking. So, after finally putting the budget together to get it all corrected, we took the plunge last month...
If any of you followed the build of Matteo Amoroso's killer 911 RSR build on Pelican Parts, or read about it in Excellence, you know it was built by Zuffenhaus here in Charlotte. One day while it was up on the lift, I noticed the wonderful front end suspension on it. So, I inquired, and started down the slippery slope to emptying my bank account.
What we now have is the 935 suspension conversion, with Fox remote resevoir coil overs all around, welded in camber boxes and adjustment plates, 375 springs around, reinforced rear trailing arm, monoball, and probably a bunch of other things I don't know about.
the work took about 2 weeks with all the cutting and welding, installation, etc.
We drove it on the track a week and a half ago to start sorting it out. We lowered the car another 1", and were finally able to give it some negative camber (we had not been able to adjust the camber enough at the height we wanted before) Right off the bat I noticed how much easier the steering was, and how much more responsive the handling was. We found we needed to take off the rear sway bar as I was getting a lot of rear wheel hop in fast corners (no, I don't have LSD yet....next years budget)
It was an absolute joy to drive. My wife, Nadine, even commented how easy is was. I went were we pointed it. It stuck MUCH better than it ever had.
We spent the weekend tweeking and tuning out anything we could find. And we really noticed the changes. Money well spent!!
Here are a few pictures of the suspension from right after we got home. Excuse how dirty it is...it got a lot of track time in 2 days!
naro914   New suspension for Papa Smurf   Mar 12 2008, 04:23 PM
naro914   more pics   Mar 12 2008, 04:24 PM
naro914   more   Mar 12 2008, 04:25 PM
Joe Ricard   SHA WING. I mean damn that's HOT!!...   Mar 12 2008, 06:03 PM
J P Stein   I've been eyeballin' that A arm set up for...   Mar 12 2008, 06:41 PM
naro914   One of the simple, but amazingly useful things Aar...   Mar 12 2008, 07:35 PM
J P Stein   Plus, at 1900 lbs..... Thar's with driv...   Mar 12 2008, 08:29 PM
naro914   Someone PM'd me about the brakes.... They are...   Mar 12 2008, 07:42 PM
naro914   no, that's without driver... trying to get it...   Mar 12 2008, 08:43 PM
J P Stein   Mine is a 74 also. Our doors weigh 64lbs each. My ...   Mar 12 2008, 09:00 PM
naro914   yep, still gotta do the doors, took out the window...   Mar 12 2008, 09:08 PM
J P Stein   I know what it is and if your happy, so be it. I t...   Mar 12 2008, 09:22 PM
naro914   Very nice! Haven't had a muffler in years ...   Mar 13 2008, 08:38 AM
ChrisNPDrider   AWESOME :beer2: That front system is blowin my min...   Mar 13 2008, 11:36 AM
sww914   Your car weighs about the same as mine and I'm...   Mar 13 2008, 12:07 PM
naro914   Your car weighs about the same as mine and I...   Mar 13 2008, 12:18 PM
naro914   so....I was standing under the car earlier this af...   Mar 13 2008, 01:10 PM
J P Stein   Well, since you're pondering....Adding tubes f...   Mar 13 2008, 05:01 PM
naro914   A lot of what you mention translates well to road ...   Mar 13 2008, 06:45 PM
J P Stein   Not much to look at, just 2 tubes from the cage to...   Mar 13 2008, 07:17 PM
Racer   Cut out the rear trunk floor.. Tie in rear shock t...   Mar 21 2008, 07:16 PM
stownsen914   Bob, Is this the same blue 914 that you and Nadin...   Mar 22 2008, 05:22 AM
naro914   Bob, Is this the same blue 914 that you and Nadi...   Mar 23 2008, 05:43 AM
- Lo-Fi Version Time is now: 1st July 2025 - 11:33 AM
