Brake parts, Brass banjo |
spunone |
Mar 17 2008, 07:27 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Ok where do you purchase the little brass part and the sealing washers that go to the Master Cyl.also the oring for the brake switch .Seems PO striped the threads on said fitting? Thanks
spunone |
Mar 17 2008, 08:52 AM
Can I just go down to the local Flaps and buy a banjo fitting?? anyone?/
sww914 |
Mar 17 2008, 09:13 AM
You should be able to get the sealing washers at your flaps, but probably not the banjo. Pegasusautoracing.com has a nice selection of banjo fittings, but somebody here probably has one, too.
lagunero |
Mar 17 2008, 02:03 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
I have one for you.
spunone |
Mar 17 2008, 02:33 PM
Thanks all gonna get from the Dr
Lo-Fi Version | Time is now: 13th May 2024 - 09:42 AM |
