What type of brake fluid should I use?, DOT 3, DOT 4, etc. ? |
levonfarra |
Mar 17 2008, 09:20 PM
Member Group: Members Posts: 173 Joined: 10-February 07 From: Encino, CA Member No.: 7,521 Region Association: None |
I use the car for street and canyon driving. My car has all stock brake system.
Thanks, Levon (IMG:style_emoticons/default/beerchug.gif) |
PeeGreen 914 |
Mar 17 2008, 09:26 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Standard DOT 4 will be fine for you. We don't put DOT 3 in anything. I am sure it would be fine but there isn't any reason why not to use DOT 4. You don't need to use any Blue or other racing fluid as you are just using it for the street. I don't think you will ever get your brakes hot enough. Just be sure to bleed them every now and again.
SGB |
Mar 17 2008, 10:29 PM
I dunno- "Canyon driving" is a potential load. I like to find DOT-4 brake fluid with a high "wet boiling point". My understanding is that the wet BP is based on fluid with some moisture content, as would be typical with a DD exposed to wet conditions. At m last flush, I put in Valvolene Synpower. It was at m FLAPS, cheap and had pretty good stats:table found by google
Lo-Fi Version | Time is now: 11th May 2024 - 07:54 AM |
