Gizwhiz Part II, Parts Identification if you please |
HillKing |
Mar 19 2008, 09:22 PM
Self taught incompetent Group: Members Posts: 62 Joined: 11-January 08 From: Cody, Wyoming Member No.: 8,563 Region Association: None |
Here are some more pieces that I have no clue about. The bolt is very interesting as the head is quite large and there is a screwdriver slot on the end of the shank.
Attached thumbnail(s) Attached image(s) |
HillKing |
Mar 19 2008, 09:25 PM
Couple of more, I kinda screwed it up.
Attached thumbnail(s) |
So.Cal.914 |
Mar 19 2008, 10:06 PM
The last ones look like the bolts and spacers for the rockers in the rear.
The one with the slot and big head kind of looks like the bolt for the headlight adjustment. |
alpha434 |
Mar 19 2008, 10:09 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Here's my guesswork.
Part 1. Shifter bushings. Part 2. Extremely rusted heater duct parts. Part 3. Doesn't belong on a 914. Part 4. Front or rear rocker spacers. |
Dave_Darling |
Mar 19 2008, 11:31 PM
The first ones look like bushings, but for what I'm not sure. (Not the shifter, not the pedal cluster...)
The second picture has the parts that hold the S-ducts onto the outlets at the bottom of the cooling fan shroud. The four bolts in the third pic look like the ones holding the bottom of the rocker covers onto the body of the car. But I thought there were three of those per side?? The slice in the fourth picture's part makes me think of the pop-up stop for the headlights. The ones in the last pic are the spacers for the rocker panels, as everyone else said. --DD |
arvcube |
Mar 19 2008, 11:40 PM
Member Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 |
just a guess...
1st pic: bushings for the dogbones for the bumpers...? 2nd pic: parts for the HE's and piping that go to the flapper boxes...? |
So.Cal.914 |
Mar 20 2008, 12:02 AM
McMark |
Mar 20 2008, 01:31 AM
1. Too small for dogbones. My guess is the center of the clutch cable wheel on the transmission.
2. Heater ducting at the fan housing. 3. Not factory 914 screws. TRASH! 4. Headlight stop. These keep the headlight from bouncing in the up position. 5. These go between the valences and the fenders. There are 8 on the car IIRC. One on either front edge of the rear valence. One at the front and one at the rear of the rockers. One on either rear edge of the front bumper. Keep those #5 pieces or sell/send them to me. |
914Sixer |
Mar 20 2008, 07:09 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The first picture is the two spacers that go in the rubber steering coupler at the steering rack.
angerosa |
Mar 20 2008, 07:34 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
#2 - Brake pads found on a car in the wreckage of the Titanic.
So.Cal.914 |
Mar 20 2008, 08:41 AM
QUOTE My guess is the center of the clutch cable wheel on the transmission. How many cars are these parts from? |
HillKing |
Mar 20 2008, 10:20 AM
HillKing |
Mar 20 2008, 10:23 AM
roadster fan |
Mar 20 2008, 11:52 AM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
could #1 be the front sway bar link bushing spacer? or are these too long? Just a guess.
Jim |
Eric_Shea |
Mar 20 2008, 01:08 PM
Are we sure #1's aren't for the lower backpad screws to go through?
McMark |
Mar 20 2008, 02:16 PM
QUOTE Are we sure #1's aren't for the lower backpad screws to go through? Yup. Those pieces are aluminum and have a 'flare' at one end to grab the backpad. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:11 AM |
