Need advise on brake bleeding problem |
Porsche Rescue |
Mar 20 2003, 06:20 PM
After replacing all 4 flexible brake lines I was unable to successfully bleed the system. Brakes worked fine before I started. Replaced the master cylinder (turned out it was needed by looking at it). Bled the system and got a good pedal. Left the car for a while. Came back to find pedal nearly to the floor. There is no evidence of any leakage. Any ideas out there?
Mar 20 2003, 07:40 PM
Resident German Group: Admin Posts: 41,603 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
did you do the bleeding alone?
Mark Henry |
Mar 20 2003, 07:58 PM
I bet it has somthing to do with the proportioning (sp?) valve. On other cars I have run into this problem before, once even going through a 4 liter jug of fluid! I finally gave up and cracked the lines as I blead. Guess what? IT WORKED. I don't recommend this method (IMG:style_emoticons/default/wink.gif) but 'what the hey'! It was messy though. (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 23rd April 2024 - 07:23 AM |
