| mattp |
Mar 30 2008, 04:02 PM
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
I have a terrible shuttering when going from standstill to moving forward in first gear only. Slightly less when warmed up, but not much better.
I checked engine mounts by putting car on jack stands and trying to jack engine up, not much movement at all, even tried jacking each side of engine alone, not much movement. Any ideas? thanks, Matt |
| sww914 |
Mar 30 2008, 06:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
That's clutch chatter. It's usually caused by bad motor mounts as you already know or a warped flywheel and/or a fried clutch. Fried clutches are not even good with ranch dressing.
| SirAndy |
Mar 30 2008, 06:51 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| degreeoff |
Mar 30 2008, 06:54 PM
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
That's clutch chatter. It's usually caused by bad motor mounts as you already know or a warped flywheel and/or a fried clutch. Fried clutches are not even good with ranch dressing. or with Bleu cheese..... (IMG:style_emoticons/default/dead horse.gif) |
| Gint |
Mar 30 2008, 07:51 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
...tastes like chicken... (IMG:style_emoticons/default/chowtime.gif) or maybe (IMG:style_emoticons/default/squirrel.gif)
(IMG:style_emoticons/default/agree.gif) It could be either a warped or torched flywheel or a bad disk. There's really only one cure and it involves cash. |
| GeorgeRud |
Mar 30 2008, 08:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Do you know what kind of disc is in the car? If it's a multi-puck disc, it's normal (but still obnoxious).
| mattp |
Mar 31 2008, 09:11 AM
not sure whats in there, bought the car about 1.5 years ago. I have a raby kit on order since November and am told it should be delivered any day now, not sure I want to tear it open to replace the clutch just to change motors in a month or so. Damn!
thanks ps. so you think I will do any real damage if I drive it a little? try to keep the shuttering down? |
| TravisNeff |
Mar 31 2008, 09:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Bad motor mounts or transmission mounts, or oil on your clutch disk
| rjames |
Mar 31 2008, 10:29 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,459 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Make sure you clutch cable is adjusted properly too. I was getting a shuddering with my car when starting out from a complete stop and it turned out that the cable just needed adjusting. The engagement point in the pedal travel had changed but I was still using the 'old' and correct engagement point.
Probably not what's happening with your car, but it's an easy thing to check. |
Lo-Fi Version | Time is now: 21st June 2026 - 04:10 PM |
