What's the point of this vent? |
dkos |
Mar 31 2008, 08:29 AM
say, "RUST"! Group: Members Posts: 295 Joined: 1-December 04 From: Philadelphia, PA Member No.: 3,204 Region Association: None |
What is the point of this vent?
blitZ |
Mar 31 2008, 08:39 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I believe it is to let trapped moisture evaporate from that part of the car.
dkos |
Mar 31 2008, 09:01 AM
It has a vent cover with a filter. Seems like it's filtering something from the engine compartment. It also vents into the passenger compartment, but there isn't a cover or filter in there.
degreeoff |
Mar 31 2008, 09:05 AM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
its there to equalize the interior/exterior pressures whilst closing the door with the windows up..... (IMG:style_emoticons/default/biggrin.gif)
charliew |
Mar 31 2008, 09:06 AM
It's to let some air out with the top on to make it easier to close the door and also to create ventilation through the cabin with the top on. The inlet air in the front can't move through the car if it can't get out.
It was designed in as there was not a factory air cond. considered at the time imo. Newer designs use a rubber one way valve. Charliew |
dkos |
its there to equalize the interior/exterior pressures whilst closing the door..... (IMG:style_emoticons/default/biggrin.gif) Really? why the filter? |
degreeoff |
Mar 31 2008, 09:08 AM
put some tape on it and the other one and try to close the door.
dkos |
Mar 31 2008, 09:23 AM
put some tape on it and the other one and try to close the door. The doors are off right now. It's a rusty mess, so it's hard to tell where it is supposed to vent. Does it just vent from the door frame into the passenger compartment? I'm wondering if I could cut all that mess out of there and run a piece of hose from door frame to the passenger area? |
davep |
Mar 31 2008, 10:18 AM
It is the cabin air exhaust. Fresh air fan brings in air, and it needs to exhaust somewhere if the cabin is fully closed up. This goes around the door seal. The filter is to prevent insects from coming through and setting up residence where you cannot find them.
thesey914 |
Mar 31 2008, 11:59 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I thought it directed air at the rear screen helping to prevent it misting up
degreeoff |
Mar 31 2008, 12:18 PM
Ah say confused-shush the piece of many puzzle always has a home!
messix |
Mar 31 2008, 12:54 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
it's there to support and connect to the tube that goes up the sail panel, that tube is there to support the foam that fills the the cavity in that area, and that foam is there courtesy of porsche to absorb water and rot the sail panel and door jam. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/chair.gif)
dkos |
Mar 31 2008, 01:01 PM
I guess my real question is...can I close it up?
Joe Owensby |
Mar 31 2008, 06:12 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I remember reading many years ago that this was the place where the air from the cabin can exhaust, say if you have the front fresh air vent open. It was located there because there is a low pressure area near the door jam when the car is travelling down the road, and thus you get better air flow.
McMark |
Mar 31 2008, 06:15 PM
I wouldn't weld it shut. Car companies don't spend $ designing worthless parts. It's there to help vent, just as others have said. Why would you want to?
Mar 31 2008, 06:25 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I wouldn't weld it shut. Car companies don't spend $ designing worthless parts. It's there to help vent, just as others have said. Why would you want to? (IMG:style_emoticons/default/agree.gif) air flowing by the door gap when you drive creates negative pressure which sucks out air from inside the car. it creates circulation when air is dumped into the car by the fresh air fan or heater. without it, no cabin air can exhaust and the fans (fresh or heat) have to work harder to push air inside the car. (IMG:style_emoticons/default/shades.gif) Andy |
Pat Garvey |
Mar 31 2008, 06:33 PM
It is the cabin air exhaust. Fresh air fan brings in air, and it needs to exhaust somewhere if the cabin is fully closed up. This goes around the door seal. The filter is to prevent insects from coming through and setting up residence where you cannot find them. Once again, Dave (as usual) has hit the nail on the head! It IS part of the (excuse the GM version) "flow-thru ventilation" system. Whatever you do, do NOT plug it up. The vent system will not work. You will never be able to recirculate the air in the cabin. You will die of suffocation (OK, just kidding about that). As McMark says - it's designed for a reason. That reason is to circulate air into & outta the cabin. The "hogs hair" filter is to keep bugs from entering when that car is parked - ask me how I know! Pat |
Lo-Fi Version | Time is now: 16th May 2024 - 02:27 AM |
