911 transaxle stubs fit |
914gem |
Mar 20 2003, 08:39 PM
Member Group: Members Posts: 91 Joined: 5-January 03 From: Greenwood Arkansas Member No.: 89 |
I was playing with parts the other day. I took a set of 1971 911 transaxle stubs and they bolted up to my 914 transaxle. The hub and hub stub fit my trailing arms. I took turbo axles and they will bolted up to the stubs the only thing is they are about 3/4 inch to short. Does anyone make spacers or can I cut and move my hub housing in to make up the space.
Brad Roberts |
Mar 21 2003, 12:33 PM
Are you sure you used Turbo axles ?? With the parts you had laying around... it sounds like you would have used early 911 axles (which are a direct bolt in) The early 911 CV is the same size as the turbo CV. Dont run the turbo CV setup with these drive flanges. You need the 4 bolt 2 pin setup that orginally ran with the flanges. Ask me how I know.
B |
Lo-Fi Version | Time is now: 17th May 2024 - 09:40 PM |
