Worked Hard on 914 today Now I Have a Headache |
LetoAtreides |
Apr 15 2008, 12:06 PM
Member Group: Members Posts: 86 Joined: 15-May 07 From: Half Moon Bay, California Member No.: 7,739 Region Association: None |
Correct me if I'm wrong, but I believe the Bursch muffler systems come with a space between the pipes that come from the headers and the muffler itself. This space is reserved for a catalytic converter or bypass pipe.
McMark |
Apr 15 2008, 12:13 PM
What year is your car? What does the rear valence look like? There are three different valences.
Spoke |
Apr 15 2008, 01:15 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Show us the muffler. This will help ID the problem. Sagging springs are a characteristic of old age. You didn't mention if you thought the shocks were bad. |
WizPorsche914 |
Apr 15 2008, 01:36 PM
Member Group: Members Posts: 128 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region |
Once I got the coil off of the shock I could press down on the shock with little resistence.
Taking a pic of the muffler now. |
1970 Neun vierzehn |
Apr 15 2008, 01:44 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
When I encounter a fastener or bolt that won't budge, after I've sprayed it with a penetrant, I try to tighten it about an 1/8 of a turn to break the threads loose before turning to remove it. That has always worked on the 914 and my old motorcycles. Also, when it comes to refastening bolts or my 914 wheel studs, I always put a tiny bit of anti-seize grease on the threads to facilitate removal at some later time.
Paul |
WizPorsche914 |
Apr 15 2008, 02:35 PM
Here it is you can see something isnt right.
WizPorsche914 |
Apr 15 2008, 02:41 PM
Apr 15 2008, 02:44 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
looks like a 1.7 muffler on 2.0 liter HE's
The 1.7 HE's have a bend that moves the muffler up higher..thus the drop in the tailpipe. the 2.0 liter has straight HE's Looks like the wrong part to me. Rich |
WizPorsche914 |
Apr 15 2008, 02:50 PM
The Car does have Stainless Heat Exchangers So maybe there not right for this car because when the muffler was bolted on it sat up way higher then the stock one. Almost touching the heat shield.
dw914er |
Apr 15 2008, 02:52 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
purple |
Apr 15 2008, 03:09 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I'm amazed no one has mentioned this yet....
loosen your lugnuts BEFORE you lift the car off the ground. something about the car putting force perpendicular to the plane you're working in makes them SUPER easy to loosen compared to doing it after the car is off the tires. |
WizPorsche914 |
Apr 15 2008, 05:48 PM
WizPorsche914 |
Apr 15 2008, 05:50 PM
Posted above is a picture taken of the end of the heat exchanger. Is it a 2.0 or 1.7 ?
Grelber |
Apr 15 2008, 06:32 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
That's a 1.7L exhaust. Besides the curve, the flange is a different size, so a 2.0L Bursch won't bolt up to a 1.7L exhaust at all.
Apr 15 2008, 09:27 PM
Those are the right HE's , they are 1.7/1.8.
Show a pic of the tranny bracket for the back muffler, a pic of the muffler out of the car and a pic of the tranny mounting in the rear (how the tranny is mounted to the car)...sumpin aint right. I have the same setup and its 1/4 inch from the valence hole, nice and tight. post Three pics. Rich |
WizPorsche914 |
Apr 17 2008, 08:33 PM
Heres the latest update. Lug bolt is off ! As soon as I bought an impact socket it took it right off. I installed the new Bilstein shocks with 100lb weltmeister springs.
As for the exhaust I put it on anyway b/c atomotion wasnt going to take it back b/c I bought it 3 months ago and was saving it for when it got warmer to work on it. Im going to look for a different (original) rear valance next week in Hershey. Next project Master Cylinder !!! |
jsayre914 |
Apr 17 2008, 10:06 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Are you keeping the exhaust (IMG:style_emoticons/default/sad.gif) like this?? |
WizPorsche914 |
Apr 18 2008, 08:53 AM
no once it mounted it looks 95% better
Lo-Fi Version | Time is now: 7th June 2024 - 05:19 PM |
