Suby-engined rustoration, 23-Mar-2021 update: new tires & wheels |
strawman |
Apr 18 2008, 12:19 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Hi All --
This is my second post, but I've been lurking on this fine website for a while now. I've wanted a 914 since I was in high school, but always seemed to stumble upon other projects... until recently. My neighbor gave me this 1973 Porsche 914 about a month ago. He told me he blew a head gasket and parked it in his parents' driveway in 1992. When his parents finally told him to move it or they were calling a local junkyard, he offered it to me since he knows I'm a gearhead. In for a penny, in for a pound... I hauled it home, knowing that it has some rust issues in the battery area and rear trunk. But it appears to have never been in a wreck and it is complete. It turns out that an exhaust stud pulled, so he coulda fixed it for a couple hundred and probably kept another 914 from languishing but I guess all things happen for a reason (namely, so I would undertake this project!). I sold the engine to a local Craigslister for use in his Meyers Manx dune buggy, and bought a wrecked but running 1993 Subaru Legacy turbo wagon. This is the closed-deck 2.2 liter engine, and 250 hp is easy with boost control and an open exhaust. I've already done a Subaru into a VW Vanagon and my daily driver is a 1992 Suby Legacy, so this won't be too much of a stretch for me. I plan to use the Suby 5-speed transmission (out of a 1998 Suby Forester) with the Aussie-sourced RWD elimination coupler and custom-mated 914/Suby axles. I've got a suburban home with a crowded two-car garage (my 125 shifter kart and my daughter's FJA kart will likely get lonely!), a MIG welder, and a wide assortment of air/power/hand tools -- so the adventure begins! This project will likely take a year to finish, so please be patient. I've attached some pics of the car as found in the driveway, some rust areas and the rear trunk repairs I've started. I'll chronicle the build as I go, so feel free to chime in! Geoff Attached image(s) |
strawman |
Aug 16 2008, 09:59 PM
Next up is a pic of the patch piece, made of 16 gauge steel. Since the factory piece used inner "ribs," I added these reinforcements made of 1" 14 ga. square tubing ripped into angle pieces. This pic shows the Metal Prep stage, prior to painting the inside with gray POR15.
Since I'm using a rotisserie, I don't want to completely muck up the dimensions by cutting out too much at a time. So I'm replacing pieces in relatively small increments, and checking to see that the suspension jig I built still lines up as I go. Here is a pic of the patch during welding into the hole. That piece will be covered with an 18 ga. outer shell, in order to attain the same thickness that the factory used (two pieces of 17 ga.). That outer shell will be welded in as soon as I provide a good foundation to weld. From a previous pic, you can see the "wall" has rusted out and portions need to be replaced -- and that area is necessary in order to install the "outer" shell. Here is a pic of the area I've cut out to complete this next phase. |
Lo-Fi Version | Time is now: 1st May 2024 - 10:00 PM |
