Suby-engined rustoration, 23-Mar-2021 update: new tires & wheels |
strawman |
Apr 18 2008, 12:19 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Hi All --
This is my second post, but I've been lurking on this fine website for a while now. I've wanted a 914 since I was in high school, but always seemed to stumble upon other projects... until recently. My neighbor gave me this 1973 Porsche 914 about a month ago. He told me he blew a head gasket and parked it in his parents' driveway in 1992. When his parents finally told him to move it or they were calling a local junkyard, he offered it to me since he knows I'm a gearhead. In for a penny, in for a pound... I hauled it home, knowing that it has some rust issues in the battery area and rear trunk. But it appears to have never been in a wreck and it is complete. It turns out that an exhaust stud pulled, so he coulda fixed it for a couple hundred and probably kept another 914 from languishing but I guess all things happen for a reason (namely, so I would undertake this project!). I sold the engine to a local Craigslister for use in his Meyers Manx dune buggy, and bought a wrecked but running 1993 Subaru Legacy turbo wagon. This is the closed-deck 2.2 liter engine, and 250 hp is easy with boost control and an open exhaust. I've already done a Subaru into a VW Vanagon and my daily driver is a 1992 Suby Legacy, so this won't be too much of a stretch for me. I plan to use the Suby 5-speed transmission (out of a 1998 Suby Forester) with the Aussie-sourced RWD elimination coupler and custom-mated 914/Suby axles. I've got a suburban home with a crowded two-car garage (my 125 shifter kart and my daughter's FJA kart will likely get lonely!), a MIG welder, and a wide assortment of air/power/hand tools -- so the adventure begins! This project will likely take a year to finish, so please be patient. I've attached some pics of the car as found in the driveway, some rust areas and the rear trunk repairs I've started. I'll chronicle the build as I go, so feel free to chime in! Geoff Attached image(s) |
strawman |
Sep 26 2008, 11:35 AM
It has been a while since I last posted and work has required more time than I would otherwise like but I haven't totally ignored my teener. Unfortunately, I didn't take a lot of time to take many pictures... but here are a few of my continuing effort of shoring up the upper/inner long & hellhole.
In this pic, you can see the outer 18 gauge "shell" that I bent up to cover the inner 16 gauge piece described above. This outer shell is tied into the inner piece and the fender wall. You can also see the AA inner suspension console. You can also see that I had to plug the suspension mounting hole, since that hole didn't line up exactly with my jig... which you can see below. The jig ties into the outer suspension holes, the inner suspension console on the driver's side, and the driver's side motor mount. Ignore bolt/washers/nut that is being temporarily stored in the slot; that bolt is lined up with the "tube" and eventual new hole in the console (two washers are spaced between the tube and console). It should be noted that AA's inner suspension console cannot be blamed for this misalignment -- I fabbed up my own upper/inner long replacement, so the suspension console required some massaging to fit, and the mounting hole was off by about 1/4". |
Lo-Fi Version | Time is now: 1st May 2024 - 05:41 PM |
