Suby-engined rustoration, 23-Mar-2021 update: new tires & wheels |
strawman |
Apr 18 2008, 12:19 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Hi All --
This is my second post, but I've been lurking on this fine website for a while now. I've wanted a 914 since I was in high school, but always seemed to stumble upon other projects... until recently. My neighbor gave me this 1973 Porsche 914 about a month ago. He told me he blew a head gasket and parked it in his parents' driveway in 1992. When his parents finally told him to move it or they were calling a local junkyard, he offered it to me since he knows I'm a gearhead. In for a penny, in for a pound... I hauled it home, knowing that it has some rust issues in the battery area and rear trunk. But it appears to have never been in a wreck and it is complete. It turns out that an exhaust stud pulled, so he coulda fixed it for a couple hundred and probably kept another 914 from languishing but I guess all things happen for a reason (namely, so I would undertake this project!). I sold the engine to a local Craigslister for use in his Meyers Manx dune buggy, and bought a wrecked but running 1993 Subaru Legacy turbo wagon. This is the closed-deck 2.2 liter engine, and 250 hp is easy with boost control and an open exhaust. I've already done a Subaru into a VW Vanagon and my daily driver is a 1992 Suby Legacy, so this won't be too much of a stretch for me. I plan to use the Suby 5-speed transmission (out of a 1998 Suby Forester) with the Aussie-sourced RWD elimination coupler and custom-mated 914/Suby axles. I've got a suburban home with a crowded two-car garage (my 125 shifter kart and my daughter's FJA kart will likely get lonely!), a MIG welder, and a wide assortment of air/power/hand tools -- so the adventure begins! This project will likely take a year to finish, so please be patient. I've attached some pics of the car as found in the driveway, some rust areas and the rear trunk repairs I've started. I'll chronicle the build as I go, so feel free to chime in! Geoff Attached image(s) |
charliew |
Jan 24 2009, 01:19 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
A burr is a term for a carbide bit that fits in a air tool. The ones I use for porting heads come in different shaft lengths and 1/4 shaft size. They have many different shapes and are good for many uses. When you use them on aluminum you will need a lubricant to keep the aluminum from sticking to the cutter. I don't remember the terminology but they have a coarse and finer tooth cutter for different materials. Finer for harder materials and coarse for the softer materials. You can get a set or buy them individually.
strawman |
Jan 25 2009, 10:26 PM
A burr is a term for a carbide bit that fits in a air tool. The ones I use for porting heads come in different shaft lengths and 1/4 shaft size. They have many different shapes and are good for many uses. When you use them on aluminum you will need a lubricant to keep the aluminum from sticking to the cutter. I don't remember the terminology but they have a coarse and finer tooth cutter for different materials. Finer for harder materials and coarse for the softer materials. You can get a set or buy them individually. Yup, Charlie beat me to the punch. I bought a set that includes a "ball" end bit, a straight bit, and a "tree" tapered end bit. The ball end bit is also great for weakening spot welds if you're tossing the removed panel piece. Here's some pics of typical bits: http://www.carbidebur.com/shapes/burs.htm If memory serves, I bought my 3-piece set at Sears about three years ago... Geoff |
strawman |
Jan 25 2009, 10:54 PM
I bought a 1969 911 rear suspension/brake system today for $75 (I love Craigslist!). The purchase included the suspension arms, parking brakes & cables, calipers and non-vented rotors. Now I have almost everything I need for my 5-bolt conversion both front and rear.
Below are some pics of the pieces I will use on my setup, based on Paul Sayegh's write-up in the February 2009 edition of Excellence magazine. Excellent article, by the way -- and very timely! Unfortunately, my budget won't allow the use of the Porsche "reds" calipers that Paul used... Pic before tearing everything apart. Here's a pic of the components I'll use. I have the backing plates, too, but I forgot to include them in the photo. Obviously, I still need to remove the parking brake pieces from the 911 "banana" arm. Some of these pieces are pretty rusty, but nothing cancerous/terminal. Like I'm scared of rust, tho! I'm thinking I'll replace some of the hardware with new and get the remainder plated. I'm hoping to upgrade to vented rotors, too, but I'll need to research my options for spacing/widening the calipers to fit 'em. Fun, fun!!! |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:29 AM |
