Suby-engined rustoration, 23-Mar-2021 update: new tires & wheels |
strawman |
Apr 18 2008, 12:19 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Hi All --
This is my second post, but I've been lurking on this fine website for a while now. I've wanted a 914 since I was in high school, but always seemed to stumble upon other projects... until recently. My neighbor gave me this 1973 Porsche 914 about a month ago. He told me he blew a head gasket and parked it in his parents' driveway in 1992. When his parents finally told him to move it or they were calling a local junkyard, he offered it to me since he knows I'm a gearhead. In for a penny, in for a pound... I hauled it home, knowing that it has some rust issues in the battery area and rear trunk. But it appears to have never been in a wreck and it is complete. It turns out that an exhaust stud pulled, so he coulda fixed it for a couple hundred and probably kept another 914 from languishing but I guess all things happen for a reason (namely, so I would undertake this project!). I sold the engine to a local Craigslister for use in his Meyers Manx dune buggy, and bought a wrecked but running 1993 Subaru Legacy turbo wagon. This is the closed-deck 2.2 liter engine, and 250 hp is easy with boost control and an open exhaust. I've already done a Subaru into a VW Vanagon and my daily driver is a 1992 Suby Legacy, so this won't be too much of a stretch for me. I plan to use the Suby 5-speed transmission (out of a 1998 Suby Forester) with the Aussie-sourced RWD elimination coupler and custom-mated 914/Suby axles. I've got a suburban home with a crowded two-car garage (my 125 shifter kart and my daughter's FJA kart will likely get lonely!), a MIG welder, and a wide assortment of air/power/hand tools -- so the adventure begins! This project will likely take a year to finish, so please be patient. I've attached some pics of the car as found in the driveway, some rust areas and the rear trunk repairs I've started. I'll chronicle the build as I go, so feel free to chime in! Geoff Attached image(s) |
strawman |
Jun 3 2009, 11:36 PM
Still been plugging away...
Below are some pics of the shortened water pipe, with the welded lip filed down. That was a major PITA, but the lip should help keep the coolant inlet hose from slipping off. Basically, I welded a "ring" around the water pipe, cut off the pipe on the aft side of the "ring," and then shaped the lip with a file. Probably more than needed, since this pipe is in "suction" and likely wouldn't slip off with a hose clamp... but I have access to an aluminum MIG setup, and I'll sleep better at night knowing the hose can't slip off. I'm also attaching a couple of pics of the final (almost) alternator setup. You can see the 0.70" spacers I spun on the lathe -- though they're still raw/unfinished -- as well as the upper mount. I still need to clean up the welds of the upper mount, trim the angle iron "connector," polish the spacers, and then paint the whole shootin' match. The belt now lines up perfectly, though I'll need to use a 3-rib belt to match the tensioner; the alternator and outer crank pulley are 4-rib. |
Lo-Fi Version | Time is now: 1st May 2024 - 05:59 PM |
