Suby-engined rustoration, 23-Mar-2021 update: new tires & wheels |
strawman |
Apr 18 2008, 12:19 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Hi All --
This is my second post, but I've been lurking on this fine website for a while now. I've wanted a 914 since I was in high school, but always seemed to stumble upon other projects... until recently. My neighbor gave me this 1973 Porsche 914 about a month ago. He told me he blew a head gasket and parked it in his parents' driveway in 1992. When his parents finally told him to move it or they were calling a local junkyard, he offered it to me since he knows I'm a gearhead. In for a penny, in for a pound... I hauled it home, knowing that it has some rust issues in the battery area and rear trunk. But it appears to have never been in a wreck and it is complete. It turns out that an exhaust stud pulled, so he coulda fixed it for a couple hundred and probably kept another 914 from languishing but I guess all things happen for a reason (namely, so I would undertake this project!). I sold the engine to a local Craigslister for use in his Meyers Manx dune buggy, and bought a wrecked but running 1993 Subaru Legacy turbo wagon. This is the closed-deck 2.2 liter engine, and 250 hp is easy with boost control and an open exhaust. I've already done a Subaru into a VW Vanagon and my daily driver is a 1992 Suby Legacy, so this won't be too much of a stretch for me. I plan to use the Suby 5-speed transmission (out of a 1998 Suby Forester) with the Aussie-sourced RWD elimination coupler and custom-mated 914/Suby axles. I've got a suburban home with a crowded two-car garage (my 125 shifter kart and my daughter's FJA kart will likely get lonely!), a MIG welder, and a wide assortment of air/power/hand tools -- so the adventure begins! This project will likely take a year to finish, so please be patient. I've attached some pics of the car as found in the driveway, some rust areas and the rear trunk repairs I've started. I'll chronicle the build as I go, so feel free to chime in! Geoff Attached image(s) |
charliew |
Sep 17 2009, 11:14 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I like the engine cradle it's similiar to Tony's. Looks good.
Are you going to expect the pinion depth to remain the same after you replace the bearings on the pinion shaft? Did you happen to check the backlash on the original setup? Just curious as I am going to put 05 legacy internals in a 02 wrx case with the obx and I saw where suby has a flat plate tool to set pinion depth. It looks like one could be made using a known good setup and using it on later rebuilds. It uses two pins that register in the case bolts and butts against the end of the pinion it seems from pictures I've seen. Since you are not changing the ring and pinion you might be ok just setting the backlash as that seems to be your game plan. Thats seems to be what the guys on nasioc are doing. I guess thats the early tranny from the 93 instead of the 99 tranny you mentioned at the first? It looks like the tt one I have. Is it a 4:11 or 4:44 fd? I read somewhere that the pre 99 tranny were different but the 96 I have looks a lot like the 02 wrx and the 05 legacy other than the clutch arm and the axle stubs missing on the 05 and the removable plate on top of the center case of the early tranny. While you are in there look how much room there is with the center diff out. I'm thinking the cables for the shifter could be internal and that would clean up the rear of the car under the bottom. |
strawman |
Sep 18 2009, 07:33 PM
<snip> ... Since you are not changing the ring and pinion you might be ok just setting the backlash as that seems to be your game plan. Thats seems to be what the guys on nasioc are doing. Hi Charlie, Yup, I'm only planning to set the backlash and test to make sure I've got a good gear pattern. I guess thats the early tranny from the 93 instead of the 99 tranny you mentioned at the first? It looks like the tt one I have. Is it a 4:11 or 4:44 fd? I read somewhere that the pre 99 tranny were different but the 96 I have looks a lot like the 02 wrx and the 05 legacy other than the clutch arm and the axle stubs missing on the 05 and the removable plate on top of the center case of the early tranny. No, I've confirmed from the part number that it is out of a 1998 Forester, with the 4.11 ratio. It has a transmission code of TY753VJ1AA. While you are in there look how much room there is with the center diff out. I'm thinking the cables for the shifter could be internal and that would clean up the rear of the car under the bottom. I'm not sure that would be possible; where would the cables enter the case? And how would you rotate the rod with the cables inside the case? I think cable shifting at the back of the trans should be fine... Geoff |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:02 AM |
