993 exhaust for 6 conversion, think it might work? |
JWest |
Mar 21 2003, 01:36 PM
Check out this pic of a 993 exhaust. I was thinking that maybe you could turn the heat exchangers around and use them on a 914. Cut the collector and point it to the rear instead of inboard. Heater tubing would have to be moded but that would not be major issue.
Can these be made to fit on earlier 911 heads? What issues might there be/what am I missing? James |
Brad Roberts |
Mar 21 2003, 06:18 PM
The flanges are thicker than the early flanges that bolt to the head. You could change studs. The other issue is: the late have a extra lip for the gasket and the early doesnt.
Late: B |
Brad Roberts |
Early:
B |
Lo-Fi Version | Time is now: 19th April 2024 - 06:58 PM |
