914 rear calipers, caliper piston size question... |
739142 |
May 12 2008, 11:21 AM
Newbie Group: Members Posts: 11 Joined: 21-April 08 From: Dallas Member No.: 8,948 Region Association: None |
I recently took the rear calipers off my 73 914 2.0 It has what mic's out to 34mm pistons or so.. when I go to the parts houses to get rebuild kits, they show 42mm for the back and 48mm for the front calipers. These look bone stock. Has anyone ever gone through this? what is the answer? I cant seem to find 34mm rebuild kits anywhere...
any help appreciated (IMG:style_emoticons/default/sad.gif) |
davep |
May 12 2008, 11:51 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
914/4 rear calipers were always 33mm
The 911 Carrera from 84 to 89 has the 48 & 42 combo, but that is far from a 914/4. |
Eric_Shea |
May 12 2008, 01:38 PM
PMB Performance Group: Admin Posts: 19,277 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I cant seem to find 34mm rebuild kits anywhere... http://www.pmbperformance.com/catalog/item...563/4747449.htm 33mm for the rear and 43 up front. Even if you did get the right kit it doesn't include all the seals. I think Doug in Canada had the same problem and mentioned it here on the board. Sounds like the big parts house databases are screwy on this one. E. |
914Sixer |
May 12 2008, 02:44 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Send them to Eric and be done!!!
739142 |
May 12 2008, 04:03 PM
Send them to Eric and be done?
HOw much is that? What is teh turn around time?? |
Eric_Shea |
May 12 2008, 05:15 PM
QUOTE HOw much is that? What is teh turn around time?? http://www.pmbperformance.com/catalog/item...552/4782980.htm Bout 1-week out right now. $249.00 plus refundable core charge. |
davep |
May 12 2008, 05:48 PM
Umm, that better be 42mm up front for all years of 914/4.
Lo-Fi Version | Time is now: 29th May 2024 - 02:48 PM |
