1974 1.8L to 2056 engine build, Start to Finish (this may take a while!) |
Rick L |
May 13 2008, 06:19 PM
Member Group: Members Posts: 405 Joined: 12-November 05 From: Columbia-ish, MD Member No.: 5,116 Region Association: North East States |
And...we're off! The goal: Build a 2056 from a 1.8L jet. We'll use the 1.8 Case and Heads, new 96mm P&C's, Raby Cam & Valvetrain kit, and, for the moment, put an Ljet or Djet back on it. Eventually it'll get dual carbs, but I can't drop the extra G just yet. I'll include as manay pics as I can. I got a little ahead of the camera with this so the engine is already out of the car, the tranny and exhaust are off and these pics show the rats nest (Ljet, harness, vacuum), throttle body, intake runners and right side tin coming off. Had to use the cell phone cam for these, future pics will be better. |
Rick L |
May 13 2008, 06:22 PM
pics
Rick L |
May 13 2008, 06:23 PM
Here's what many years under a tree w/o a rain tray will do for your motor!
SGB |
May 13 2008, 06:24 PM
GREAT!
It is really hard to stop and take the pictures when you are making progress AND too filthy to touch the camera (or phone especially) I even put my oldest dig camera in the garage and still don't document all the stuff I do. Good luck with the engine. Sounds like a good plan. Take your time, and check then recheck everything. Keep those pictures coming! |
crash914 |
May 13 2008, 06:38 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
When did you take those?
I guess I got to look in the garage more often..... sure that you did not take pictures of my motor? |
type47 |
May 13 2008, 06:43 PM
cool, columbia MD even. even cooler, 74 1.8 even (IMG:style_emoticons/default/biggrin.gif) maybe you can find some parts this weekend at the carlisle import/kit car event.
plymouth37 |
May 13 2008, 06:49 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
God speed! Get to work!
Cevan |
May 14 2008, 01:15 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Question: (I keep kicking this idea around all the time because I have a couple of 1.8 motors lying around just begging to be converted to a 2056). If you put carbs on down the road, won't you need to put in a new cam to take advantage of the carbs?
Rick L |
May 14 2008, 05:48 PM
Question: (I keep kicking this idea around all the time because I have a couple of 1.8 motors lying around just begging to be converted to a 2056). If you put carbs on down the road, won't you need to put in a new cam to take advantage of the carbs? The way I understand it, no. Jake says that you cam it the same regardless of FI or Carbs. You just won't get the full HP advantage out of the FI, it acts like a fuel governer. FI = 110-115HP, Carbs = 120-125HP. Herb, I stopped in for a couple hours on Monday and went to town. You busy Friday? I've got a mid-day meeting but would like to do some more on both our cars. Have I mentioned that I'm STOKED!! I intend to drive this bad boy to ECC this fall! (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif) |
Rick L |
May 14 2008, 05:49 PM
orange914 |
May 15 2008, 06:59 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
did you go with the 9550 cam? remember NOT to run more than 8.3:1 if you'll be running o.e. injection. thats why you'll limit yourself in h.p. if you dont keep comp. down and run the f.i. you'll probably burn a piston. ask many of the members here.
good luck with the build, and definately have a plan on what carburation your engine will run on the finished project. just be careful not to damage all that expense and effort before the carb install |
orthobiz |
May 15 2008, 07:43 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I thought the 1.7 and 1.8 could only go to 1.9 liters????
Paul |
orange914 |
May 15 2008, 07:46 PM
crash914 |
May 15 2008, 08:04 PM
Rick, I will be home Fri at around 5:00.. I know the wife wants family time, but if you were already here......see ya later...
Gint |
May 15 2008, 09:56 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Good for you. You do realize that in addition to what you listed in your first post that you also need a 71mm stroke crank and 2.0 rods to make 2056 right? Otherwise, you're creating a 1911.
crash914 |
May 16 2008, 04:19 AM
Wife is working today, so it is all yours...we can put the motor up on the engine stand to help with the disassembly...
Rick L |
May 16 2008, 09:00 PM
Sorry Herb, got roped into house projects today. The wife discovered I was off today and took the day off too. I'll call you this weekend and re-schedule.
Kenny, thanx for the comp ratio info. I hope to have the carbs by the time I finish the build so I don't have to F with the FI. I am purchasing the 9550 cam. Gint, I'm on it. I intent to harvest a crank and rods from one of Herb's 2.0 motors. Have I mentioned Herb rocks?! I really appreciate the time, the garage, the tools......what kind of beer do you like again? |
Rick L |
Jul 6 2008, 07:20 PM
Herb and I finally got the case cracked. 30 years of wear and tear were very evident. It was also apparent that the heads had been off as well. Each cylinder had a stack of 4 shims. I never did a leak down test on the motor because I knew I was gonna pull it, but I'll bet you can look at the pics and tell me what the results would have been!
Now it's of to Jake's with the crank, flywheel, clutch, and rods for balancing. Here's a look at what we found, btw, it was dirty! Caution: Dirty engine porn! |
Rick L |
Jul 6 2008, 08:01 PM
Here are the p&c's:
1&2 3&4 |
Rick L |
Jul 6 2008, 08:08 PM
The shims, spread so you can see all 4.
And the valves: 3 & 4 the 1, 2 head was unremarkable |
Lo-Fi Version | Time is now: 9th June 2024 - 02:31 AM |
