What AUTO-X Tire do you use? Wheels too!, Tires for AUTO-X and Racing |
bjinright |
May 15 2008, 09:39 AM
Newbie Group: Members Posts: 13 Joined: 9-June 06 From: Montgomery, ALABAMA Member No.: 6,192 |
I've opened this thread to see what everybody likes Rubber-wise. (well that came out wrong) (IMG:style_emoticons/default/confused24.gif)
Anyway for AUTO-X iv been using: Falken Azensis 615 205/50R15 in C stock on stock Fuchs(sp) But I'm looking to see what others have been succesfull with in: CS STS2 (up to 225mm but are the 215s working for anybody?) SP MOD I'm also wondering if you use tire size to "regear" your 914. |
GaroldShaffer |
May 15 2008, 11:33 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Kuhmo V710 205 50 15 in DSP / SM2 on Minilite rims
PeeGreen 914 |
May 15 2008, 12:14 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I like the Kumho V710s and for my street tires I like the Toyo RA1s. I also use those when it rains at the AX and they are amazing.
bjinright |
May 15 2008, 02:48 PM
I don't mean to harp on this but what size?
I'm thinking of going to STS2 until I get some money for the "STICKY STUFF" As it stands now, I think my 205/50s have lowered my top speed so I'm running out of 2nd gear too early at auto-X. |
May 15 2008, 03:40 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I've opened this thread to see what everybody likes Rubber-wise. (well that came out wrong) (IMG:style_emoticons/default/confused24.gif) 9" GoodYear R250 on 15x7 Cookie Cutters (IMG:style_emoticons/default/driving.gif) Andy |
Heeltoe914 |
May 15 2008, 09:45 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Andy I like the way you keep the rims close to your heart. (IMG:style_emoticons/default/biggrin.gif)
I just tryed the RT 615 Flakins and for the price very good rubber. with a four banger I thinks its just enought grip to not bind up the car in tight corners But lets its resr come around nicely. I ran them all day last week at the Streets of Willow and thay never let me down. Only downside is thay are alittle heavy. |
May 15 2008, 09:56 PM
Andy I like the way you keep the rims close to your heart. (IMG:style_emoticons/default/biggrin.gif) did you notice the shotgun shell in the center? (IMG:style_emoticons/default/shades.gif) Andy |
PeeGreen 914 |
May 16 2008, 12:25 AM
Oh, sorry, I run 225/ 50 R15s on 15x8 Fuchs.
Joe Ricard |
May 16 2008, 06:55 AM
1st I think the 914 will do very well STS2
Which means you can go to a 7.5 inch rim and 225mm rubber either 15 or 16" dia. the Hottest tire on the course for street tire class is the Bridgestone RE-01R Followed by the Yokohama Advan Neova Budget tires in that class is the Azenis and then Hankook RS-2 and Kumho MX However most of these tires larger than 205mmsection width will not fit under stock fenders. I have run lots of tires from Hoosier R3S04 (225/45-15 to RS-2 (225/50-15) all the way up to slicks 22.5 x9.5 x 15 from a formula atlantic car. Now running some tires from AVON 240/600 R15 The more stick you have the more spring you will need or you will "bind" as you say. If I were to get mega serious about this I would run 275/35-15 Hoosier A6 and never put more then 30 competition runs on the set before religating them to practice. |
jhadler |
May 16 2008, 03:00 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
I don't mean to harp on this but what size? I'm thinking of going to STS2 until I get some money for the "STICKY STUFF" As it stands now, I think my 205/50s have lowered my top speed so I'm running out of 2nd gear too early at auto-X. Top speed is not what wins autoxes. If you go up in gearing, your 2nd will top out at a higher speed, but your acceleration out of the corners will suffer. And seeing as most autoxes don't give you a lot of long straights, and do give you a whole heck of a lot of turns, I'd go for the shorter tire package. Now... If you want more stick, and not loose gearing, the Hoosier 225/45-15 or the 275/35-15 both have the same effective diameter as the 205/50-15. If you're going for taller tires in autox, then you really need the torque to back it up... -Josh2 |
Joe Ricard |
May 16 2008, 03:52 PM
My experiences mirror Josh's perfectly.have courses that get you
If you have courses that get you topping out 2nd try short shifting to 3rd earlier. Thetorque of a 2.0L will make you faster. If you really want to up the ante and class rules allow re-gear 3rd to a flipped ZD. |
yarin |
May 16 2008, 10:14 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Ran a used set of A6s last season, this year I've got a few autoxs on a fresh set of Avon Tech RAs that I picked up on clearance from Tirerack. Also have a fresh set of V710s as well. All 205/50/15.
grantsfo |
May 16 2008, 11:37 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I agree with Joe on STS tire RE-01R is top street tire. Hoosier is top DOT R.
I use Goodyear R250 canti slicks on 9.8 lb Jongbloed 15x8 wheels. I can buy used qualifying tires with a couple laps on them for $80 a piece and they last half a season of AX and track events! This post has been edited by grantsfo: May 16 2008, 11:41 PM Attached thumbnail(s) |
Justinp71 |
May 20 2008, 11:45 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I ran Kumho v710's 205/50/15 and 205/50/15's on 15x7 and 8's fuchs last weekend, they stuck very well and I've heard that they will last for awhile.
BTW... What class are the sixes in ('75 2.7 CIS)? I thought that I was in ASP, but someone else told me SM2... |
mskala |
May 20 2008, 11:48 AM
jhadler |
May 20 2008, 12:08 PM
I ran Kumho v710's 205/50/15 and 205/50/15's on 15x7 and 8's fuchs last weekend, they stuck very well and I've heard that they will last for awhile. BTW... What class are the sixes in ('75 2.7 CIS)? I thought that I was in ASP, but someone else told me SM2... ASP if it's the STOCK 2.0L six. SM2 if it's got any other Porsche made power plant (including any other six, air or water cooled). -Josh2 |
Justinp71 |
May 20 2008, 06:58 PM
Last weekend there was a viper in ASP, kind of hard competition for a 2.0 six. Especially considering that the 2.0 4cyl is only like 10hp less and is in DSP.
jhadler |
May 21 2008, 05:47 PM
Last weekend there was a viper in ASP, kind of hard competition for a 2.0 six. Especially considering that the 2.0 4cyl is only like 10hp less and is in DSP. I know this sounds like a pointless exercise, but... write a letter. No, really. It's terribly obvious that the six shouldn't be in ASP, but until the SCCA gets letters from people asking for reclassification, it'll remain in ASP because they've got a cr*p load of other cars to worry about that have far more people driving them. There are very few actual 914-6's out there (compared to BMW M3s, Vettes, Civics, Miatas etc.), and even fewer that still have an original unmolested 2.0L motor in them. So it's no so much that they have deliberately classed the six against the latest and greatest ubercars, it's just that it's soooo not on their radar, that they've left in in the same class it was originally placed in back in the 80's... Really, write a letter. Pick a few cars today that you can compare the car to. Use things like weight, power, torque as basics for comparison. I would tend to say that the 2.0L six might be able to better find a home in CSP, against the miatas of today (no small task, let me tell you). At least then, it's in a class with similar cars... Just saying that the six has only 10 hp more than four won't work though. That's in stock form, and SP gives a lot more capabilities to some cars under the allowances. If a 2.0L six was given unlimited intake and exhaust modifications (as is allowed in SP), I think the gap between the 2.0L four and the 2.0L six would be a bit wider... Just my $0.12 (inflation ya know...) -Josh2 |
ClayPerrine |
May 22 2008, 09:19 AM
Life's been good to me so far..... Group: Admin Posts: 15,436 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Last weekend there was a viper in ASP, kind of hard competition for a 2.0 six. Especially considering that the 2.0 4cyl is only like 10hp less and is in DSP. You now see the reason Betty and I don't run SCCA AX any more. 914s were successful in SCCA autocross for years, then they got legislated out of competitiveness. |
J P Stein |
May 22 2008, 10:47 AM
You now see the reason Betty and I don't run SCCA AX any more. 914s were successful in SCCA autocross for years, then they got legislated out of competitiveness. Candy ass. Running without the day before's practice, Brit finished 14 OA at our last SCCA AX. Bout 120 cars ran. Results: ----------------------------------------------------------------------------- 1m AM 17 Ryan Otis 08 LRC 58.303 2m PCSP 190 Ron Bauer 07 Mazda MX5 60.046 3m PSM2 160 LJ Moffet 01 Corvette Z06 60.232 4m PFM 83 Sheldon Lemoine 90 KBS MKV 60.911 5m PCSP 90 Jim Daniels 07 Mazda MX5 61.269 6m AM 7 Neal Stanley 06 LRC 61.388 7m PSM2 60 Scotty B White 01 Corvette Z06 61.406 8m PFM 183 Ernest Fanthorpe 90 KBS MKV 61.463 9m RASP 59 Mark Snell 06 Lotus Exige 61.621 10m PBSP 97 Doug Skinner 73 Porsche 911 61.777 11m PSS 11 Kevin Dietz 04 Corvette Z06 62.081 12m FRUN 90 Tami Daniels 07 Mazda MX-5 62.120 13m PCSP 83 Jack Yeung 07 Mazda MX5 62.289 14m EM 41 Britain Smith 74 Porsche 914 62.419 15m WCSP 90 Tami Daniels 07 Mazda MX5 62.904 16m RSS 111 Ming Yip 06 Lotus Elise 62.932 17m PES 95 Jerry Jenkins 94 Mazda Miata 62.968 18m WSM2 60 Angela Moffet 01 Corvette Z06 62.972 19m FRUN 998 Geoff Clark 03 Mitsu Evo 63.028 20m SS 8 Denis Cornforth 08 Corvette Z06 63.063 21m PSM2 124 Enrique Garcia 99 Mazda Miata 63.112 22m SS 181 Jerry Lee 04 Corvette Z06 63.150 23m RSM 75 Don Nimi 91 Nissan 240SX 63.385 24m SM2 9 Bob Bundy 90 Mazda Miata 63.496 25m STU 21 Geoff Clark 03 Mitsu Evo 63.642 Most all these cars practiced on the day before on the same course run backwards. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:48 AM |
