111 953 553, Windshield washer valve |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
davep |
May 18 2008, 07:06 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The 914/4 used the air pressure of the spare tire to pressurize the washer fluid tank. This valve, found in the steering column, regulates the flow of washer fluid when you pull back on the washer lever. A small pin is used to actuate the valve.
Note the small differences between the NOS part (with the cap) and the used part. The used part has a hex base for the tubes and a metal bridge tying the tubes together. The metal bridge is loose on the NOS part, so the bridge was not designed for it. This electric switch, which I have designed, is mounted in place of the valve to permit an electric pump solution similar to the 914/6. |
Lo-Fi Version | Time is now: 18th May 2024 - 04:54 AM |
