push rod tube seals, does the oil need to be drained? |
tod914 |
May 18 2008, 07:34 PM
Does the oil in the car need to be drained out when the push rod tube seals are going to be replaced? Not sure if that's where the leak is on the new 74 I picked up, but just trying to pre-plan so I'm not changing the oil 2x. Thanks, Tod |
May 18 2008, 07:41 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
nope
SGB |
May 18 2008, 10:22 PM
tod914 |
May 19 2008, 12:05 AM
Danka
Cap'n Krusty |
May 19 2008, 12:37 AM
If you jack the car up at an angle, you're gonna take a bath from the forward tubes. The Cap'n
ericread |
May 19 2008, 01:18 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
However, since you're going to be goofing around under the car anyway, what a perfect time to change the oil. And since you're probably taking care of oil leaks, you might want to replace the taco-plate seal, which requires the oil to be drained. Don't forget the oil cooler seals. Then fill it with yummy Brad-Penn oil. Your teener will love it! |
Cap'n Krusty |
May 19 2008, 09:47 AM
In 35 years of working on 914s, I have yet to see a leaking "taco plate" o-ring, unless it's been slathered with RTV, the crush washers are missing, or the bolts/threads are messed up. the Cap'n
Lo-Fi Version | Time is now: 22nd May 2024 - 08:25 PM |
