the $5k engine....., this one is on the road! |
Aug 16 2008, 09:27 PM
A Big step up from a 2.0 liter. hmmmm Yes, a BIG step up from a stock 2.0L ... Obviously not in displacement, but rather in power, torque and the grin factor. Going from ~90 HP to ~125 HP is a big step up in our little cars. That's about 40% more power! (IMG:style_emoticons/default/piratenanner.gif) Andy |
McMark |
Aug 16 2008, 11:55 PM
By the numbers a 2056 doesn't seem like a large increase. But like most things, the numbers don't tell the whole story. The combo that Jake has put together is a real, and noticeable improvement, as Scott has mentioned.
scottb |
Aug 17 2008, 01:18 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
exhaust leak is fixed!!!! (IMG:style_emoticons/default/aktion035.gif)
now i don't sound like a pack of firecrackers as i get to a stop light...... so with a smooth exhaust note and a fresh exterior wash and interior vacuum, i think i added about 10-14HP. if i had cleaned the windows, who knows what the dyno would say!!!! regardless, you want a great motor, get this one. i will check in on occassion as the miles add up. but being in new england, it will be about 40 degrees below zero in about a month so i may be somewhat delayed.... cheers and thanks again to everyone who has made this engine/trans work out so well. scott |
914werke |
Aug 17 2008, 06:04 PM
"I got blisters on me fingers" Group: Members Posts: 10,085 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
What have you recognized interms of gas mileage? (IMG:style_emoticons/default/idea.gif)
scottb |
Aug 17 2008, 08:09 PM
haven't really checked yet.... will try to follow and let you know. gut is i am in the upper 20's at present but will pay more attention. cheers, scott |
Dr Evil |
Aug 17 2008, 09:26 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
That tranny seems to be doing well (IMG:style_emoticons/default/smile.gif)
scottb |
Aug 18 2008, 06:51 AM
mike, trans is doing great! also, i still have the windshield molding we had talked about before your little 'incident'. if you still want it for the new car that is with scotty b, let me know and i will get it to him or you. i am seeing if i can squeeze the time to get to the ECC so maybe i can just deliver it. cheers, scott |
ChrisFoley |
Aug 19 2008, 08:18 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
trans is doing great! ... Replacing the loose roll pin and worn ball lever helped I'm sure. How about the limited fore-aft travel with the JWest linkage upgrade? Did you do the extra clearancing needed to help select 2nd/4th? We are about to work on another box with excess play in the forks and try to tighten up the slop by improving internal clearances. |
scottb |
Aug 19 2008, 08:23 AM
QUOTE How about the limited fore-aft travel with the JWest linkage upgrade? Did you do the extra clearancing needed to help select 2nd/4th? was a quick fix once i got info from james/ed.... needed to remove a bit more material due to interference with the front of the new console on the trans. had no problem with 2nd/4th but was having issues engaging 3rd. and yes, the roll pin and worn ball lever replace helped as well! cheers, scott |
JmuRiz |
Aug 25 2010, 11:41 AM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Zombie thread......
Just wondering after driving the car for 2 years with the new 2056, how's it been treating you? Have you gotten used to the power yet, or is it still a nice surprise? FYI, I'm responding to this old one since I see there has been a lot of talk about 2056 rebuilds recently and this is one of the few full reviews. |
JmuRiz |
Jun 23 2011, 11:20 AM
10-month bump:D
For some reason...even though I have a 2.7 911 engine, carbs, oil tank, headers, muffler, sheetmetal...I'm still intrigued by this WAY easier upgrade option. Scottb, how's the car running/feeling. |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:15 AM |
