What to do with 14" Fuchs?, Here's an idea... |
URY914 |
Jun 5 2008, 08:26 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Found this pic on a nutter forum.
Gint |
Jun 5 2008, 08:35 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I need bookends. I have to do that!
mskala |
Jun 5 2008, 11:29 AM
Only 1 problem, Fuchs are probably too light for good bookends (IMG:style_emoticons/default/smile.gif)
Add lead to the backside |
SLITS |
Jun 5 2008, 12:21 PM
I run 'em on a /6 conversion. So what's the problem?
sww914 |
Jun 5 2008, 12:48 PM
Someday those 14" fuchs will probably be worth a fortune. There was a time when a 914 wasn't even worth cutting up to make a couch out of it and now really nice /4's are bringing big bucks.
URY914 |
Jun 5 2008, 12:57 PM
Wonder if a steel wheel cut in 4ths would sell?
TeenerTim |
Jun 5 2008, 03:21 PM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
Only 1 problem, Fuchs are probably too light for good bookends (IMG:style_emoticons/default/smile.gif) Add lead to the backside Just put some rubber feet or a rubber strip on the bottom. |
So.Cal.914 |
Jun 5 2008, 03:30 PM
QUOTE Only 1 problem, Fuchs are probably too light for good bookends Add lead to the backside Just put some rubber feet or a rubber strip on the bottom. Or Stick-on lead balancing weights, funtional and appropreate. (IMG:style_emoticons/default/smile.gif) |
Jun 5 2008, 03:42 PM
what tool would you use to cut these aluminum wheels?
I have tried a bandsaw...blade gets filled up with aluminum to fast. Cut off wheel, nope... Sawzall, yes, but not to accurate. Rich |
dw914er |
Jun 5 2008, 03:46 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
that is a cool addition to ones library
car themed reading anyone? Library stocked with georges 700 tech tips, haynes manual, and you're set! |
HeloMech |
Jun 5 2008, 03:54 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
or you could just give them to me to run on my car... (IMG:style_emoticons/default/smile.gif)
914pwer |
Jun 5 2008, 06:23 PM
Member Group: Members Posts: 66 Joined: 14-August 07 From: sweden Member No.: 7,999 Region Association: None |
this is what i did with mine
nein14 |
Jun 6 2008, 02:11 PM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
URY914 |
Jun 6 2008, 03:05 PM
A 911 BBS
Eric_Shea |
Jun 6 2008, 03:11 PM
Mine are going on the trailer. (IMG:style_emoticons/default/wink.gif)
914Mike |
Jun 6 2008, 03:16 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
You guys do realize that all the best Low Rolling Resistance tires are only available in 14"? (IMG:style_emoticons/default/dry.gif) I'd be looking for a set of 14's for my EV conversion if I had not already added vented rotors front and rear under the 4-bolt Fuchs thanks to Mueller's hubs and Eric's V-Kits... (IMG:style_emoticons/default/beerchug.gif)
Still working on the conversion. (IMG:style_emoticons/default/welder.gif) Anyone got 12 Group 24 12V batteries they don't need? I just nwant to borrow them, so I can do some (IMG:style_emoticons/default/driving.gif) ! I could use a set for the Ghia someday. |
nein14 |
Jun 6 2008, 05:49 PM
Dominic |
Jun 7 2008, 12:58 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I need a nice 14" x 5.5" Fuch spare for my -6...let me know befor you cut up any more. (IMG:style_emoticons/default/chair.gif)
Sly Dog |
Jun 7 2008, 05:12 PM
Newbie Group: Members Posts: 17 Joined: 27-August 06 From: Reno Member No.: 6,740 |
I need one for a spare. I went completely stock with my car #9140431910.
brant |
Jun 7 2008, 05:14 PM
Eric, I had intended to do that once upon a time and then got scarred off about load rating the factory used these wheels on cars that weighed less than 3000lbs I got to thinking that a loaded trailer may exceed some safe weight limit, and I don't want to find out first hand what that limit could be. brant |
Lo-Fi Version | Time is now: 15th May 2024 - 10:51 AM |
