Oil Gallery Plugs-Pictures please! |
justme |
Jun 6 2008, 05:25 PM
Member Group: Members Posts: 187 Joined: 1-January 07 From: southampton ma atlantic northeast Member No.: 7,413 Region Association: North East States |
Hi,
Never did a replacement job and my machinist (IMG:style_emoticons/default/headbang.gif) is confused( no type 4 work, but he's free) Please.... can anyone post pictures or diagrahm's of the 5(I believe) gallery plugs that need to be drilled & tapped. I know there are casting marks that are round and that's what's causing the confussion. If he drill's & tap's any of those(in the galley) will it junk the case?? Thanks for the HELP!! (IMG:style_emoticons/default/beer.gif) |
ericread |
Jun 6 2008, 09:04 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Hi, Never did a replacement job and my machinist (IMG:style_emoticons/default/headbang.gif) is confused( no type 4 work, but he's free) Please.... can anyone post pictures or diagrahm's of the 5(I believe) gallery plugs that need to be drilled & tapped. I know there are casting marks that are round and that's what's causing the confussion. If he drill's & tap's any of those(in the galley) will it junk the case?? Thanks for the HELP!! (IMG:style_emoticons/default/beer.gif) Dude, you've got to learn the "search" function! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/biggrin.gif) Take a look here: http://www.ephotomotion.com/914engine/page10.htm This is from : http://www.ephotomotion.com/914engine/ And definitely get an account on the Jake Raby site. Then go to the Super Duper Oil Gallery Plug Article: http://forums.aircooledtechnology.com/show...ght=galley+plug Good luck! (IMG:style_emoticons/default/bye1.gif) |
justme |
Jun 7 2008, 08:53 AM
Hi Eric & THANKS!!
I did a search but couldn't find that thread (IMG:style_emoticons/default/confused24.gif) Is there a 5th plug?? Can you pull the motor & do a leaking plug with the motor assembled? I thought maybe a shop vac & compressed air might do the job and keep shavings out of the galley's???? Thanks for the HELP! (IMG:style_emoticons/default/beerchug.gif) |
Jun 7 2008, 09:00 AM
If you really have a desire to do a plug while the motor is assemlbed (not a good idea) then use heavy grease on the tap.
Go very slow..1/4 turn each time...then pull the tap and clean it off. Add new grease, go in a bit more .... the grease keeps the shavings on the tap..but only so much, so you have to keep pulling the tap out and cleaning it really well. Please go look at Jake Raby's article about how to put in galley plugs. Its really well done, he put alot of effort to share this with us. It explains all of it. Lastly, I think he explains how to do it with the motor still assembled. Rich |
Lo-Fi Version | Time is now: 15th May 2024 - 12:17 PM |
