low acceleration/power?, tune up? |
yellow914 |
Jun 8 2008, 02:30 PM
Member Group: Members Posts: 183 Joined: 28-March 08 From: San Jose, CA Member No.: 8,861 Region Association: Northern California |
I changed my points, plugs, cap, rotor..inslalled newer Monza exhaust (thanks to Steve in Texas, it sounds great!)...but seems I need to really bring up the RPM to get power...like the power curve is now in the higher range?...Also I had one plug wire pop off the end cap on the connector. It might be getting less spark....so I'll replace that. Any suggestions would get appreciated.
thanks Scott |
type47 |
Jun 8 2008, 05:45 PM
always check the simple basics first, dwell, timing, fuel pressure, vacuum leaks, distributor advancing correctly, parts compatibility.....
Lo-Fi Version | Time is now: 13th May 2024 - 07:46 PM |
