914 air conditioning, What to do folks? |
southernmost914 |
Jul 30 2008, 06:34 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Photo of same brackets and Sanden 505:
attachmentid=152028] Attached image(s) |
jjs3rd914 |
Jul 30 2008, 09:48 PM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
I too used a York to Sanded adapter on a DPD system which we converted to 134a. We modified the brackets to allow for an easier adjustment and less hardware. All new barrier hoses were used with the new compressor. The system works great with 40 deg. vent temperatures at higher RPM. Only problem is engine is a 1972 1.7L and not a lot of HP. Had to rig up an additional air valve to get more air on idle as car would die from the load.
Hope the picture help. jjs3rd914 |
Joe Owensby |
Jul 30 2008, 10:18 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Did you have to have any idler pulleys with this last set up? I have adapted a Sanden compressor to a York Mount that came with a parts car. This adapter had a small idler pulley that ran under the bottom side of the belt, just inside the compressor. I assumed this was needed to provide clearance, but was wondering from your photos if it was really needed. I plan to rework my mount the next time I have to remove the engine, to something similar to what you have, as it looks to be much easier to adjust the belt tension. Thanks for sharing the photos. JoeO
bandjoey |
Jul 30 2008, 11:15 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
And then there's Option C
bandjoey |
Jul 30 2008, 11:18 PM
Seriously...here's a shot of body work up front where the condensor goes..This is the strongest and cleanest setup I've seen...not mine, but getting ready to do mine this way. (IMG:style_emoticons/default/smash.gif)
jjs3rd914 |
Jul 31 2008, 08:59 PM
Did you have to have any idler pulleys with this last set up? I have adapted a Sanden compressor to a York Mount that came with a parts car. This adapter had a small idler pulley that ran under the bottom side of the belt, just inside the compressor. I assumed this was needed to provide clearance, but was wondering from your photos if it was really needed. I plan to rework my mount the next time I have to remove the engine, to something similar to what you have, as it looks to be much easier to adjust the belt tension. Thanks for sharing the photos. JoeO If you notice we did not even use the York bracket to which the Sanden adapter was to mount. We just drilled a couple of extra holes on the adapter itself and made the slotted adjustment pieces. Yes our original York mount had a idler pulley. On this new setup we had to slightly modify the oil cooler bracket for clearance, but otherwise no other mods for the belt to clear. It took several attempts to finally get the right belt length for proper adjustment. By eliminating the York bracket we also saved some weight and space. In a later post there is a picture of the front truck reinforcement frame. We also did the same thing and welded in a 1/2" square tubing frame to "fix" the hack job the dealer had done when the car was new. About the only other upgrade we might do in the future to the stock DPD system is to replace the original fan and motor on the condensor with a "SPAL" multi-blade fan for more air flow. jjs3rd914 |
Joe Owensby |
Jul 31 2008, 09:15 PM
Thanks for the info. This will be a big help when I clean up my installation. JoeO
Jul 31 2008, 09:20 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
How is the belt run on these systems???
Rich |
Joe Owensby |
Aug 19 2008, 11:01 PM
The aftermarket system on my parts car had a small (maybe 6" diameter) pulley located behind the cooling fan. It replaced the washer/spacer behind the fan. the belt runs out the passenger side of the car, just in front of the oil cooler. Mine had a small idler pulley just below the pulleyon thecompressor. I am not sure if this was to tension the belt, or to raise it a little for clearance purposes. It actually contacted the "V" belt on the outer surface and raised the belt up a little. JoeO
jdamiano |
Feb 3 2019, 06:18 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
For anyone using this for reference as I did. My car has the VPC system. I got a Sanden 505 and York to Sanden bracket. I had to cut a slot in the bracket to make it work but it put the pulley almost in the exact same location. I got the stock size belt to fit but it is tight with none of the adjustment spacers installed. I would have purchased a one inch longer belt had I known. Now I just need to replace the hoses and charge the system.
Attached thumbnail(s) |
jdamiano |
Feb 3 2019, 06:29 PM
Oh and another thing I learned. I noticed the bracket connected to the engine was loose when I was taking things apart. I thought the nuts were just loose but it was there were rubber bushings that completely disinagrated. I was able to use some rubber hose to replace them.
jdamiano |
Feb 3 2019, 08:24 PM
Here is the belt I used. It worked but was tight.
Superhawk996 |
Feb 7 2019, 04:19 PM
914 Guru Group: Members Posts: 5,742 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
tmessenger |
Feb 7 2019, 08:07 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
Unfortunately, moisture in the air condenses when temperatures drop below the dew point. This means you end up with the wet seat literally, you need an evaporator coil in a box with a drain to carry condensate out of the cars interior.
Tim A more helpful parts store might have a picture/spec book for compressors that you could look through and find something. Or, you can search for other cars which used that same unit and see if someone else found anything. That compressor is not a 914 specific part, so it was undoubtedly used on other cars. Or there is always the idea of making an adapter plate. I was just thinking about this today, and had a brainstorm. Run fluid lines inside of the seat upholstery, run a tiny A/C setup that will cool a fluid tank instead of cooling air, then pump the chilly fluid through the seats. I would think that the size of the A/C system would be very small. Maybe even small enough to run an electric compressor... (IMG:style_emoticons/default/idea.gif) |
ejmetz |
May 21 2019, 11:17 AM
Newbie Group: Members Posts: 17 Joined: 28-August 18 From: Atlanta Member No.: 22,438 Region Association: South East States |
Has anyone used the 914 retrofit system from Classic Auto Air? Would love to see a pic of the installation.
https://www.classicautoair.com/shop/1975-po...tioning-system/ |
dr914@autoatlanta.com |
May 21 2019, 12:01 PM
914 Guru Group: Members Posts: 7,813 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we are about to do two 914 installations in the next two weeks
Has anyone used the 914 retrofit system from Classic Auto Air? Would love to see a pic of the installation. https://www.classicautoair.com/shop/1975-po...tioning-system/ |
Literati914 |
May 21 2019, 04:00 PM
Senior Member Group: Members Posts: 1,432 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Has anyone used the 914 retrofit system from Classic Auto Air? Would love to see a pic of the installation. https://www.classicautoair.com/shop/1975-po...tioning-system/ Don't know if you realized it, but the link (that you added) has TWO pictures and the second one shows it installed in a 914. Hopefully someone else will show us another install, for variety.. For me - I wish all the venting wasn't on the passenger's side. |
Amphicar770 |
May 21 2019, 06:30 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Numerous existing threads in this topic. Here is one.
http://www.914world.com/bbs2/index.php?sho...p;hl=Compressor |
Lo-Fi Version | Time is now: 23rd April 2024 - 01:03 AM |
