campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,635 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Had a weird issue trying to update (replace) an existing avatar.
It picked up the new width and height I entered, but it kept the old JPEG. I entered a new image in the upload filename box (using the browse button) but it didn't seem to upload the new image. Got around it by using the URL instead, and putting the new JPEG on my web server. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Same thing happened to me, but when I came back and logged on the avatar was switched to the new one.
Geoff |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
this is prolly a browser issue...
the avatar image is called av-##.jpg (or .gif) the ## stands for your member number Geoff i.e. is member #24 and his avatar is called av-24.jpg Now, if you upload a new avatar. That pic will have the same file name as the old avatar Your browser reads the same filename for the pic and shows you the cached pic instead of reloading your new one Cheers, Jeroen |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
If that's the case, Shift+Reload should cure that. Worst case, you can dunp cache and reload.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
None of the above.
Look right below the area where you set the size. There is a checkbox that says: Dont use the current avatar. Hit this first and THEN upload your new avatar. I had to do this last night. B |
Lo-Fi Version | Time is now: 18th July 2025 - 07:50 PM |
