Need help identifying plug, [edit] Mystery solved. |
914Sixer |
Jun 21 2008, 08:55 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
On 75 or 76, 2L D-jet, the mystery plug is the auto speed limiter that cuts off the fuel for California engines ONLY. It is mounted on the battery tray just like the L-Jet double pole rely. See page 9 of the 75 Factory Dealer information guide. Relay part # is 039.906.021A.
Cevan |
Jun 22 2008, 12:00 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
On 75 or 76, 2L D-jet, the mystery plug is the auto speed limiter that cuts off the fuel for California engines ONLY. It is mounted on the battery tray just like the L-Jet double pole rely. See page 9 of the 75 Factory Dealer information guide. Relay part # is 039.906.021A. I compared it to an extra L-Jet ignition harness and it's an exact match. It even has the yellow wire that plugs into the quadruple connector at the relay board. The only difference I can see is that L-Jet uses pin 12 on the 12 pin connector to go to the dual relay and D-Jet uses it to go to the AAR. Seems like an easy thing to modify. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:07 AM |
