Ugh..., Organization is such a b*tch |
dbgriffith75 |
Jun 23 2008, 12:39 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
For the most part, when it comes to mechanic work, I'm pretty organized. But for as long as I've had this '75 2.0 torn apart, it was bound to happen that I'd lose some of the information I wrote down as I was disassembling it. In this case, the wiring harness connections at the relay board.
I would think it's pretty easy to figure out, given that each wire is a certain length coming out of the harness and I should be able to just match it up to the correct pin that way, but I'm never one to just guess. And besides, one thing I remember in particular is that not all of the connections on the board were being used- some of them had been skipped. I think it was the 14 pin I found this on. Anyway, can anybody point me towards a source for figuring out which wire goes to which pin, for both the 14 and 12 pin connections? Thank you! |
Lo-Fi Version | Time is now: 19th May 2024 - 03:25 AM |
