022.256.205.A, Heater Valves |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
GaroldShaffer |
Oct 28 2006, 10:19 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Porsche orginal heater flapper box part # 022 256 205 A Left side I believe.
I will post better pictures tomorrow. Attached image(s) |
davep |
Jun 28 2008, 04:17 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
These are the heater valves that supply or dump the heat from the heat exchangers on the type 4 engine. The 914/6 valves are different, but similar. There are minor differences between these valves sold as replacement items in the 1980's and the original items installed by the factory. The dump cap is less angular and more rounded on the installed valves.
notice the symmetry of the clamps matches the lever arms |
Lo-Fi Version | Time is now: 26th May 2024 - 01:46 PM |
