> what does this sound like to you, tuning help needed
G e o r g e
post Jul 1 2008, 12:16 AM
Dr
Setting my engine timing at 28 degrees at 3500 rpms I get backfiring/ popping
can this be caused by fuel starvation?
or is this because of another issue
i'm using the mark on the fly wheel to set timing
any tips on trouble shooting?
Replies(1 - 6)
PeeGreen 914
post Jul 1 2008, 12:19 AM
Well, I'm kinda going through the same thing right now. Yes, when it pops it is lean, as I understand it,. I really can't help you out much more as I am out of my league when it comes to carbs. I'm just learning.
G e o r g e
post Jul 1 2008, 12:45 AM
Dr
not carbs
but i can increase fuel values
PeeGreen 914
post Jul 1 2008, 01:16 AM
fuel injection? Hmmm... I don't really know why that would be happening with fuel injection unless there was an exhaust leak.
jmill
post Jul 1 2008, 01:20 AM
Green Hornet
Is it popping out of the intake or exhaust? Lean pops are out of the intake.
Dr. Roger
post Jul 1 2008, 02:36 AM
A bat out of hell.
is your ignition system healthy?
custom setup?
Jake Raby
post Jul 1 2008, 06:40 AM
Engine Surgeon
Always verify mechanical integrity first.. This means a leak down and compression test are done first.
If the engine checks out with no mechanical issues then I'd say you more than likely have a funky injector and that causing a single cylinder to lean out. if it does this on acceleration, try both low and high speed ACCEL enrichment and see if it gets better.
- Lo-Fi Version Time is now: 17th March 2026 - 11:55 PM
